Author Topic: "choke" light  (Read 10306 times)
Offline lukeman
"choke" light
« on: April 19, 2012, 02:35:03 PM »
Anyone know where the sensor/switch is that turns on and off the 'choke' light is?  Mine is staying on constantly not even when it is turned off.
Thanks!
Offline wmax351
Re: "choke" light
« Reply #1 on: April 19, 2012, 03:21:28 PM »
I believe it is under the fast idle cam, on the throttle bodies. Most of the bikes don't have the switch, but just the wire and bulb.
  • Albuquerque, NM
Bikes:
Re: "choke" light
« Reply #2 on: April 19, 2012, 03:41:58 PM »
They stopped installing the switch in 1990.  The wiring is still there in the later bikes' wiring harness though.  All you need is the little spacer ring (13541460926)and the switch. (61311459569)
Offline wmax351
Re: "choke" light
« Reply #3 on: April 19, 2012, 04:19:15 PM »
It can also be used as an auxiliary signal light. For example: radar detector, running light power, etc.
  • Albuquerque, NM
Bikes:
Re: "choke" light
« Reply #4 on: April 20, 2012, 03:17:48 AM »
Also check your choke linkage at the end of the TB`s and cable adjustement: link.
Inge K.
Offline lukeman
Re: "choke" light
« Reply #5 on: April 20, 2012, 10:55:13 AM »
Wow great document!  Thanks. I figured it had to be down there somewhere along the throttle.  Going to dig into it this weekend.  Probably also a good time to check the boots for vacuum leaks.
