"choke" light
Topic: "choke" light (Read 10303 times)
lukeman
Motobrick Curious
"choke" light
April 19, 2012, 02:35:03 PM »
Anyone know where the sensor/switch is that turns on and off the 'choke' light is? Mine is staying on constantly not even when it is turned off.
Thanks!
wmax351
Re: "choke" light
Reply #1 on:
April 19, 2012, 03:21:28 PM »
I believe it is under the fast idle cam, on the throttle bodies. Most of the bikes don't have the switch, but just the wire and bulb.
Albuquerque, NM
91 BMW K75 Standard, 98 Moto Guzzi California EV
Agree x 1
View List
frankenduck
Adrninistrator
Re: "choke" light
Reply #2 on:
April 19, 2012, 03:41:58 PM »
They stopped installing the switch in 1990. The wiring is still there in the later bikes' wiring harness though. All you need is the little spacer ring (13541460926)and the switch. (61311459569)
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
Agree x 1
View List
wmax351
Re: "choke" light
Reply #3 on:
April 19, 2012, 04:19:15 PM »
It can also be used as an auxiliary signal light. For example: radar detector, running light power, etc.
Albuquerque, NM
Inge K.
Re: "choke" light
Reply #4 on:
April 20, 2012, 03:17:48 AM »
Also check your choke linkage at the end of the TB`s and cable adjustement:
link.
Inge K.
Norway
lukeman
Motobrick Curious
Re: "choke" light
Reply #5 on:
April 20, 2012, 10:55:13 AM »
Wow great document! Thanks. I figured it had to be down there somewhere along the throttle. Going to dig into it this weekend. Probably also a good time to check the boots for vacuum leaks.
"choke" light
