hyd fluid leaking K100
Topic: hyd fluid leaking K100 (Read 3862 times)
jeffhestand
April 16, 2012, 10:06:43 AM »
hi- i have a 85 K100 i am rebuilding. There is hyd fluid leaking from under the master cylinder. Easy fix or what is the most likely culprit?
thanks jeff
Scott_
Administrator
Re: hyd fluid leaking K100
Reply #1 on:
April 16, 2012, 05:54:06 PM »
sounds like you may need to either
1: clean the mc real good, pull the piston and steel wool the inside bore good.
2: find/buy an overhaul kit(basically new rubber for the piston) for same said mc.
3: replace with new mc.
My Garage
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
