Author Topic: hyd fluid leaking K100  (Read 3989 times)
jeffhestand
« on: April 16, 2012, 10:06:43 AM »
hi- i have a 85 K100 i am rebuilding. There is hyd fluid leaking from under the master cylinder. Easy fix or what is the most likely culprit?
thanks  jeff
Re: hyd fluid leaking K100
« Reply #1 on: April 16, 2012, 05:54:06 PM »
sounds like you may need to either
1: clean the mc real good, pull the piston and steel wool the inside bore good.
2: find/buy an overhaul kit(basically new rubber for the piston) for same said mc.
3: replace with new mc.
