Author Topic: Leaky rear shock - Will a K100 shock fit a K75?  (Read 7581 times)
Offline awfers
« on: March 06, 2012, 02:45:07 PM »
On close inspection of my rear shock, I noticed a slight bit of oil on the plunger, and a bit of gunk accumulated at where the shock body travel stops on the plunger. (It's installed upside down)
I'm guessing the shock is toast at this point? Any recommendations for replacements? Or can it be rebuilt? (or did I just start an oil discussion?)
Thanks,
Awfers
Offline frodef
  • 1986 K75C
Re: Leaky rear shock
« Reply #1 on: March 06, 2012, 02:49:24 PM »
My (original) shock stared leaking a while back. I replaced it with a RAM shock, and I'm quite pleased with that choice. http://www.realmengineering.com/page15.html
Rick G
« Reply #2 on: March 06, 2012, 07:17:46 PM »
+10 on that. I just installed one on the K100 and I am really happy with it.
« Reply #3 on: March 06, 2012, 08:26:49 PM »
If you buy a shock from Realm then make sure that you have it sprung properly.  Their default is to spring them for 2-up fully loaded riding.  I got one for my K75 (which I usually ride 1-up at 165# with little or nothing else) and it was WAY too stiff.  I got another spring from them with the right spring rate and it works MUCH better.
Offline awfers
Leaky rear shock
« Reply #4 on: March 12, 2012, 11:12:42 AM »
Thanks all.. Off to Ebay to find a cheap used one.
Will a shock off a later k100 work? Local moto wrecking yard has a couple...
Thanks,
Mark
Offline electric_monk
Re: Leaky rear shock - Will a K100 shock fit a K75?
« Reply #5 on: March 15, 2012, 04:26:46 PM »
The shock on the later 16v models is definitely longer than the earlier ones by about 25 mm.
