Author Topic: Where to send drive shaft for rebuild  (Read 21515 times)
Offline conybeare
  • Conybrick
« on: February 24, 2012, 07:56:50 PM »
Hi All,
I am not having much luck finding a used drive shaft in decent condition for my '90 K75S, so I'm considering a rebuild instead. Is Bruno's (http://www.brunos.us/) the only option? I have done some searches but haven't turned up any other places. Just wondering if people have heard about any other shops that will do this.
And in case anyone is curious, Bruno quoted me $160 for the rebuild without a new u-joint (just new spline collar), plus $30 for shipping.
Thanks!
  • Saint Paul MN
Nothing :o
Previous: 2004 R1100S, 2009 Yamaha FZ6,1990 K75S, 1986 K75C, 1984 Honda VT500 Ascot, 1981 Suzuki GS250T
Offline DRxBMW
Re: Where to send drive shaft for rebuild
« Reply #1 on: February 24, 2012, 08:05:34 PM »
Hansens:
http://www.hansensmc.com/default.asp?page=spline
For the record, your are NUTZ if you choose NOT to R&R the UJ. Consider the repair to be proactive.
$160 is a bargain, ride a sport-bike sometime. Chain & sprockets will set you back $200 - $300 or more.
Bruno does good work, I have a revamp done by him that has 130K mileage factor, very minor wear on the splines.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Offline conybeare
  • Conybrick
« Reply #2 on: February 24, 2012, 08:19:35 PM »
Thanks for the info! I thought the u-joint was something that doesn't wear much :embarass:
Looks likes Hansens charges $200 for the same job... so Bruno's it is! And I'll go with the u-joint, too  :2thumbup:
  • Saint Paul MN
Nothing :o
« Reply #3 on: February 24, 2012, 09:03:52 PM »
Hansen's doesn't rebuild drive shafts, only final drives.  They recommend buying a new drive shaft from BMW.
Offline DRxBMW
« Reply #4 on: February 24, 2012, 09:23:48 PM »
:hmm:  you are correct about the above comment.
Seem to remember Curry mentioning something about Hansen and drive shafts but I'm WRONG, case closed.
Bruno must be the "only game in town" then, interesting.
Gary
Williamsport,Pa
2005 F 650 GS
« Reply #5 on: February 24, 2012, 09:29:53 PM »
They emailed for some part a couple of months ago.  I was curious about their spline work so I asked.
Here's what I got back:
Quote
We rebuild the spline on the pinion, but we don’t rebuild the driveshaft.
$199.99 for the pinion repair out of the rearend.
Driveshafts we replace new, but give a 20% discount on shaft with pinion repair.
About 2 weeks turn around once the pinion has arrived.
If you don’t have the tools to remove pinion, send us the complete rearend.
1 ¼ to R&R pinion & reseal, or 2 ½ to for complete rearend plus parts.
Craig Hansen
« Reply #6 on: February 24, 2012, 10:28:16 PM »
I had great luck with my shaft from Bruno's. He makes it better than it came from BMW, which is good. The shaft is the main weakness on these bikes.
Offline Krock
« Reply #7 on: April 19, 2012, 12:12:35 PM »
Hi everybody
My drive shaft is about to break!
Bruno's will deliver a fully rebuild dual u joint drive shaft for a k1100 for $450 + taxe(s) + delivery: Witch equal to too much money for a somewhat simple part.
I am presently searching for the U-joints only in order to  replace them myself. Anybody knows the dimensions of the u-joints or a manufacturer? I figure $100 is what it should cost including a little machining.
K1100 92
Thanks
« Reply #8 on: April 19, 2012, 12:45:58 PM »
A drive shaft kept properly lubricated can easily last 100,000 miles or more so IMO it's more of a wear item (or failure caused by lack of proper maintenance.)
« Reply #9 on: April 19, 2012, 03:18:51 PM »
That is true. Although with the upgrade and proper lubrication, it is a lifetime item.
Not sure why they cant do the shaft splines like the old airheads. Big beefy thing, bathed in gear oil.
Offline jay1622
« Reply #10 on: August 19, 2015, 10:57:53 AM »
Well, I removed the final drive off of the swingarm and some gear oil came out. The source is the input seal for the final drive. Have you guys had any luck replacing these (the seal), or do you recommend sending it out? Are the two places mentioned in this older thread still recommend? Anybody newer?  This final drive is very tight; absolutely no backlash. None at all. The bike only has about 32,000 miles on it. I don't imagine a rebuild as necessary; just the final drive input seal perhaps?
I am not sure if you can see it in the picture, but just sitting on my table, the gear oil is pooling at the bottom of where the seal is.
Oh, and the last knucklehead that worked on this bike? There was black RTV at the mating surface between the swingarm and the final drive. Somebody got lazy.
  • Charlotte
Offline Kontoboy
« Reply #11 on: October 04, 2015, 10:51:47 AM »
Just received an email and Bruno's is not taking any work right now.  I'll check back in a couple months.
Offline FONG
« Reply #12 on: September 29, 2016, 05:33:28 PM »
Has anybody heard from Bruno's about this?  My K75 splines just took a header and I've had no reply them (and the phone number gave a suspiciously generic message).
  • Colorado Springs
  • '91 K75S
« Reply #13 on: October 01, 2016, 07:41:52 AM »
I read here last year that Bruno will be out of commission for 2016 due to health issues. We wish him the best and hope for a full recovery -- he's been an irreplaceable resource for the K-Bike community over the years.
In the meantime there's this, but apparently only for UK customers.
https://www.motobins.co.uk/displayfinal.php?s=0&function=show&subs=073b&title=K+20+SPLINE+DRIVESHAFT+EXCHANGE+SERVICE&model=
Doesn't address the U joint, seems to be only a weld-on spline replacement.
This motobrick.com topic gives the rebuild roundup -- but most of the parts mentioned are for the R100, so not even sure whether they're K-ompatible.
http://www.motobrick.com/index.php/topic,6675.msg45399.html#msg45399
« Reply #14 on: October 01, 2016, 09:19:51 AM »
I just bought a new  Ei new driveshaft from Ted at beemershop.  Awesome.  It is how  bmw should have made them in the first place.
« Reply #15 on: October 01, 2016, 09:29:21 AM »
Except for that one little correctable glitch supporting the ancient maxim Errare humanum est. :giggles
  • 1995 K75 89,000 miles
« Reply #16 on: October 01, 2016, 09:38:44 AM »
Lol, yes....but company shipped new one from Taiwan overnight to make it right.  Impressive!  Now I just need to install the replacement....
« Reply #17 on: October 01, 2016, 09:43:44 AM »
You mean this one?
http://www.beemershop.com/Merchant5/merchant.mvc?Screen=PROD&Product_Code=TRA54063
That is made in Taiwan?
I would have considered that but I had a $200 gift card at Bob's BMW, so I went OEM.
« Reply #18 on: October 01, 2016, 09:48:37 AM »
Yup.  Greasable/replaceable u-joint.  Shock dampers built into fat part of tube.  Very nice part.
The R-bike community swears by these things.
Offline qwertymotobrick
« Reply #19 on: January 24, 2018, 03:49:20 PM »
Bruno still works?
  • russia moscow
  • k100rs 1991 16 v
« Reply #20 on: January 24, 2018, 04:11:43 PM »
I don't think so.  Bruno has had some serious health issues in the past year or so.
There was a video from Chris Harris a few weeks back explaining how he(Chris) sold his home and shop and was invited to come up to Bruno's shop in Ontario to run it, but he was not allowed entry into Canada.
Offline technostructural
« Reply #21 on: February 01, 2018, 03:38:35 PM »
That is some exciting news. Based on his video, it appears that he is still trying to make this happen. The K community needs both Bruno and Chris. I hope that this can work out.
  • Halifax, NS
« Reply #22 on: February 01, 2018, 03:54:35 PM »
It's a shame that borders only exist to block the movement of people from civilized countries...
