Author Topic: Harbor Freight Value  (Read 66219 times)
Offline DRxBMW
« on: February 14, 2012, 09:49:25 PM »
Rate your satisfaction/dissatisfaction with specific tools or items purchased and used from Harbor Freight. Note the link to the item, if you got it on sale, a photo if you can, and your DIRECT experience with that item.
Anyone who is interested in buying inexpensive tools and items from HF can use this thread to see if what they are interested in has a chance of being worth the price!
PLEASE this thread is NOT about whether you should buy things from China,India,Mexico,wherever on the planet..  It IS about helping bricKhead's decide the good values Vs bad at Harbor Freight. Please do not waste our time with rants about HF and Chinese ch*t.
I'll kickstart the thread:
microfiber cleaning/polish cloths, PASS, 4 for the price of one compared to Auto Zone. ($3.99 on sale)
http://www.harborfreight.com/microfiber-cleaning-cloths-pack-of-4-68440.html
Medium strength thread sealant (aka loctite), FAIL, nut vibrated off, buy the good stuff. ($2.99)
http://www.harborfreight.com/threadlocker-no-42-10-ml-medium-strength-65192.html
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Offline motodude
Re: Harbor Freight Value
« Reply #1 on: February 15, 2012, 01:39:17 AM »
I recently purchased an auto-darkening welding helmet.  $49.99 and I wonder how I ever got along w/o one.  The headgear is even of reasonable quality.
Half the price they usually run at Napa or AirGas.
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
« Reply #2 on: February 15, 2012, 09:41:18 AM »
Their brake bleeder works fine and it's on sale everyonce in a while:
Their cheap, cheap fake dremel tool has no power whatsoever and was a waste of $10:
« Reply #3 on: February 15, 2012, 11:59:31 AM »
I bought a small combo metric/SAE socket set at HF once.  The socket labeled 10mm (the one most used on K bikes) was actually a 9mm socket.  :laugh
« Reply #4 on: February 15, 2012, 01:35:08 PM »
I've got their Bike lift. Works fine. Cheap too.
I had a grinder from them last 10+ years, including stripping 4 motorcycles, and countless other jobs. I tossed it when it started making horrible noises after I got a cheap Makita while working at Home depot.
Most of the stuff is actually pretty decent, as long as you are willing to do your own quality control.
I have one of their 1200 watt generators. Works nicely. Just check for metal shavings in the gas tank/carb before starting up.
I have also had one of their compressors. little 5 gallon? pancake type one, oil type compressor. Worked for a long time, till I eventually toasted the motor (while sandblasting with it none-the-less) and manage to buy a 23 gallon one from Home depot on clearance sale.
http://www.toolcrib.com/blog/2008/08/buyer-beware-a-harbor-freight-buying-guide-the-good-enough-the-bad-and-the-abysmal
« Reply #5 on: February 15, 2012, 01:50:49 PM »
quick stitch sewing awl...
first time i used it the needle snapped in half on the very 1st stitch...
« Reply #6 on: February 15, 2012, 02:09:30 PM »
wood burner... got it to do some low tech plastic welding...
tip broke off the first time i tried to use it...
« Reply #7 on: February 15, 2012, 02:13:26 PM »
lightweight soldering iron...
would not get hot enough and never once got hot enough to melt solder...
« Reply #8 on: February 15, 2012, 02:17:49 PM »
truck crane...
the bottle blew its seals 5 times in 2 years before i tossed it...
« Reply #9 on: February 15, 2012, 02:22:07 PM »
I just bought several 98 cent soldering irons from a 98 cent store. Convenient to have several, but not counting on them lasting. That's why I also have a nice soldering station. Still chinese, but good quality
http://www.sciplus.com/singleItem.cfm/terms/16663
American Science and Surplus can have some gems. http://www.sciplus.com/
Offline motodude
« Reply #10 on: February 15, 2012, 04:00:25 PM »
Johnny, you should stop purchasing tools from Harbor Freight.  :nono
'95 K75RT
'90 K75RT
« Reply #11 on: February 15, 2012, 05:34:00 PM »
i have only made 5 purchases at harbour fraght in my lifetime... hope to keep it that way...
« Reply #12 on: February 15, 2012, 06:26:35 PM »
Love these little buggers, usually 2 for $3.  The aaa batteries included cost that much.  Put them in the desk, car, bike toolbox, give them to the kids.  One at work goes through hell and does fine.
« Reply #13 on: February 15, 2012, 06:36:40 PM »
When my dremel went belly up I picked up the HF one for $15 on sale,  does fine.  The $12 heat gun is handy for heating steering head bearings and thawing pipes.  Both are fine for occasional use.
Offline DRxBMW
« Reply #14 on: February 15, 2012, 07:39:46 PM »
Their brake bleeder works fine and it's on sale every once in a while:
Rick bought the same brake bleeder for his 1150 GS. Lasted about one month before total meltdown.
FAIL ________________.
Gary
Williamsport,Pa
2005 F 650 GS
Offline DRxBMW
« Reply #15 on: February 15, 2012, 07:40:51 PM »
Ya, I have the same flashlights stashed in various locations.
PASS ____________________.
Gary
Williamsport,Pa
2005 F 650 GS
Offline HCorn
« Reply #16 on: February 15, 2012, 09:03:42 PM »
There's no shortage of garbage at HF, but there's a few gems. I'll list the PASSES:
I can't speak highly enough about the 5 drawer Tool Cart. Good luck finding something as good for 3x the price ($160):
The 42" Tool Chest is also great ($360), although I think the cart is superior:
The composite ratchets are surprisingly smooth and strong at under $10 and it won't freeze you widdle fingers when it's cold out:
Although not as durable as Hansen trays, the socket trays are a bargain at $10/set:
With a handful of purchases, in particular those above, I have been downright amazed at the quality/value. That being said, there are some things I'm really hesitant to buy: Anything you plug in (unless you're trying to build a fire); and anything your life might depend on (i.e. jack stands).
There's a great Harbor Freight Pass/Fail thread over at Garage Journal:  http://garagejournal.com/forum/showthread.php?t=27192
1986 K75T
« Reply #17 on: February 15, 2012, 09:55:42 PM »
Screwdrivers, air tool attachments, air hose reels, hoses, pliers, voltage meters....all a plus.
Offline motodude
« Reply #18 on: February 15, 2012, 10:26:21 PM »
Thanks HCorn, I'm in the market for a roll-around cart/table.  I'll give that one a look-see.
I have purchased jack-stands and a cherry-picker from HF.  So far they've worked flawlessly.  I'm in the process of putting an sbc/700r4/D300 into a Wagoneer.  The cherry-picker lifts all three as a unit w/o any issues.  And, the engine has all the appliances on it (alt, psp, acp, maniforlds, tbi).  It also lifted the AMC 360/TH400/D20 as a unit, out w/o any issues.
I agree about electrical (plug-in) appliances/tools though.  A lot of their stuff, you can just look at and see that it is not well built.
Tom
'95 K75RT
'90 K75RT
« Reply #19 on: February 17, 2012, 12:26:06 PM »
snapped opening up my ram hole...
Offline DRxBMW
« Reply #20 on: February 17, 2012, 03:55:35 PM »
Quite obvious a Warlock has spelled a "Voodoo curse" on Harbor Freight tools and JO for breakage.
Gary
Williamsport,Pa
2005 F 650 GS
Offline motodude
« Reply #21 on: February 17, 2012, 04:07:52 PM »
I'm just glad I don't have a, "ram hole".   :embarass:
'95 K75RT
'90 K75RT
« Reply #22 on: February 17, 2012, 06:20:23 PM »
ummm, you really gotta use the tool for the intended purpose to judge it fairly.  That said, my 1/2" Craftsman ratchet made a lousy hammer, but they replaced it for free!
Offline Lawrence
« Reply #23 on: February 17, 2012, 06:53:35 PM »
I bought a chain breaker/master link installer.  The skinny bit that is used to press out the old master link bent.  I straightened it and then it snapped when I tried to use it again.
1985 K100RS
1982 Laverda Mirage 1200TS
1983 BMW R100RS
« Reply #24 on: February 17, 2012, 10:11:04 PM »
HF has the same break it and return it policy with all its hand tools. and in general, they hold up very well, especially without moving parts.
i bought one of their clicker torque wrenches. its really solid, comes in a nice case, and is quite accurate. iirc, its the 15 inch one. was on sale.
With my racing team at uc berkeley, we either get really goood stuff donated or buy the cheapest crap we can find.
the HF bench grinder is quite good, and has put up with quite a bit of abuse.
the blasting cabinets can easily be made nice.
my portable, bottom/hose fed sand blaster gun works well.
i have heard that the mini metal lathes are excellent, once you adjust the preloads correctly. you can add a milling attatchment, and have a good machining setup for 500 dollars. (20 % off one item codes are always around)
wire brushes suck, but do their job. they're a buck a pop, and arent supposed to go over 4000 rpm, but work great on grinders. they shed metal hairs, but not a big deal outside with a face mask (also from hf) or a paintball mask, like i use.
i have a couple sets of their metric tap/die kit. the taps and dies are nice, but the die holder and large T handle for the taps suck and are made of sintered crap metal. theyre so cheap, i can overlook that, and buy a decent tap holder.
the 1/2 inch impact sockets are quite good, as are the U joints and extension
