Author Topic: Harbor Freight Value  (Read 66796 times)
Re: Harbor Freight Value
« Reply #50 on: March 13, 2016, 06:27:48 PM »
This $10 bag of goodies might come in handy for those of us who have 2-pin battery tender plugs hooked up to our bike.
http://www.harborfreight.com/solar-power-connection-cable-kit-68684.html
Positive and negative battery clamps
Male cigarette lighter power plug
Female cigarette lighter power port
Dual two pin keyed connector
LED charge indicator
12 volt adapter cable
Offline Scud
« Reply #51 on: March 13, 2016, 07:16:08 PM »
I got a used HF bike lift (found on Craigslist) and it's still going strong. Very happy with it.
Also happy with some metric deep impact sockets and a pair of breaker bars (3/8 and 1/2 drive). Although I have not yet used these sockets with an impact wrench.
http://www.harborfreight.com/12-in-drive-18-in-breaker-bar-67932.html
How can you go wrong with cheap hammer?  This min-sledge has been great for driving out wheel bearings and other stubborn things.
http://www.harborfreight.com/2-12-lb-hardwood-drilling-hammer-67816.html
As an aside - I really like the Pit Posse wheel bearing remover (not available at Harbor Freight).
  • Carlsbad, CA
« Reply #52 on: March 13, 2016, 07:31:33 PM »
I will admit that I buy almost all my tools at Harbor Freight now(I still won't buy anything with a motor, sprays paint or has a cutting edge, though).  However, for single sockets, you still can't beat Sears Craftsman.  I just bought a 30mm socket for $9.  Couldn't get it at any price at HF.
Judging from the look of the store I was in,  I would hurry and get what I need while they're still in business.
« Reply #54 on: June 29, 2017, 11:25:49 AM »
This thread needs a bump.  I got these a couple years ago an they get used a couple times a week.  Worth having around.
« Reply #55 on: June 29, 2017, 11:40:24 AM »
I am waiting and waiting hoping that they start up in OZ.
Regards an impatient Martin.
Offline Al
« Reply #56 on: June 30, 2017, 11:50:02 PM »
Might this be part of the problem?
  • Manitoba
  • K75RT
Four wheels move the body. Two wheels move the soul.
« Reply #57 on: July 01, 2017, 09:49:46 AM »
I've found a few things like rags, acid brushes, panel tools and have known folks pleased with the tool chests and the MC lift table but I would never buy anything that needed an accurate calibration or value.  The wrenches and sockets are good for a base to bend and weld to make specialty tools.
Offline Andy FitzGibbon
« Reply #58 on: July 01, 2017, 10:39:26 AM »
I have been using their Pittsburgh "Professional" combination wrenches for nearly 20 years now, and haven't broken one, even with hard use and occasional abuse.
The five drawer tool cart mentioned a couple pages back is indeed a very nice piece. All of the US General boxes are. They're built to a higher standard than a lot of the no name HF stuff.
I've also had a HF steering wheel puller kit for over 20 years, and it's been quite handy (used it to pull several Japanese motorcycle flywheels). They still sell the same kit.
Just drilled twelve 3/4" holes in my shop floor (to mount a car hoist) using one of their SDS MAX rotary hammer bits, and it performed flawlessly.
It's kind of like going to Vegas... everything is a gamble, but sometimes you beat the house.
Andy
  • Montrose, WV
« Reply #59 on: July 01, 2017, 06:58:13 PM »
I stay away from most of the electrical stuff, battery, plug in or diagnostic.  Recently bought their 3 ton low profile floor jack with 20" lift, $74 on sale, love it.  Also picked up their MC wheel balancer,  worth it even for a couple tires a year.
Offline jakgieger
  • itinerant farmer
« Reply #60 on: July 02, 2017, 12:04:28 AM »
:hehehe ...wife and I are going to see Corb in Tulsa OK
  • Kansas USA
  • 1989 K100rs se
Offline RobP
« Reply #61 on: July 02, 2017, 11:16:21 PM »
Their pneumatic sheet metal nibbler is designed  for and works fine on 18 gauge sheetmetal.
The large 3" tubing/pipe cutter is unworkable.   The cutting wheel is cockeyed at an angle and won't track in the same groove, basically it just creates a spiral groove up the length  of the pipe.
  • Driftwood, TX
  • 1985 K100RS
« Reply #62 on: July 03, 2017, 01:03:48 AM »
Rob amongst other things I used to be a pipe fitter, and you can experience the same problem with expensive Ridgid pipe cutters. You can overcome this by applying a bit of a twist on the cutter to compensate. The larger the diameter pipe the more chance of cutting a spiral.
Offline White Dog
« Reply #63 on: July 05, 2017, 10:44:31 AM »
I've used my $69 HF motorcycle lift for several years, hoisting my 940+ lbs. Gold Wing without any problems.  As soon as I figure out what mounts to make, I can use it for my K75 and R1100RT.
I also have 3 different click type torque wrenches I use and they have never failed.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
