Author Topic: Fork Boots - Anybody use 'em?  (Read 30032 times)
Offline TaosBrick
  • RedHotMotoBricker
« on: February 03, 2012, 11:40:46 PM »
I live in a dry, dusty environment, where gravel (and sometimes bigger things) are often spewed from under tyres of vehicles in front, or fly off of trucks coming from gravel pits in the opposite lane (ouch!).
So I'm guessing these would be a good investment, yes? (I am also trying to up my number of posts to actually reach 'novice motobricker' status) :bmwsmile
- Samurai Maxim
Re: Fork Boots - Anybody use 'em?
« Reply #1 on: February 04, 2012, 12:19:19 AM »
greetings motobrick curious taosbrick..
somebody needs to get a fork protection post in the lieberry...
most folks use the rancho brand of shock boot #1952...
i use the traxxion dynamics fgk1...
Offline DRxBMW
« Reply #2 on: February 04, 2012, 12:38:25 AM »
JO are the Traxxion protectors universal fit ?
website makes NO reference to diameter, so I'm assuming so.
Installed Daystar boots on the GS, damn thing overheated, forced to remove them.
Touratech makes a similar model to your Traxxion but EXPENSIVE. The only difference is, there taller in length. Cloned from Triumph aftermarket I think.
Thanks, I've been in search mode for a solution, as I pound gravel laden tarmac all the time.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
« Reply #3 on: February 04, 2012, 01:16:22 AM »
The K75F has K1100 forks.
Offline DRxBMW
« Reply #4 on: February 04, 2012, 07:45:23 AM »
perfect fit on the rs motobrick.. can go a little larger or a little smaller in slider diameter i guess... not very tall but protects the general area of travel...
side view k75f...
Ordered a pair of the Trax protectors for the GS five minutes ago. I think they will fit OK. Plus, the price was right.
Surprised NO one ever invented a "zip lock or velcro" type boot for a motorcycle fork yet. I've seen shorter zip lock models for ATV's before in my travels.
Gary
Williamsport,Pa
2005 F 650 GS
« Reply #5 on: February 04, 2012, 08:01:46 AM »
Offline DRxBMW
« Reply #6 on: February 04, 2012, 09:08:34 AM »
http://www.ascycles.com/detail.aspx?ID=43209
I've used neoprene covers on my high end mountain bicycle before with dismal results. Retain moisture,swear they trap the grit worse then leaving the sliders bare naked. Granted, easily removal for inspection purposes though.
Old style R rubber boots on my K 75 whip since she was new. I kinda like the nostalgia GS image factor they portray.
FWIW, my mantra is the clean bare sliders on all my toys with Isopropyl alcohol on a regular basis.
Your biggest concern is a stone that actually chips the slider surface. Rare but it does happen occasionally. Tip, back off if another bike or cage is throwing/spitting stones in front of you if possible.
Consider additional headlight protection if run gravel tarmac with trucks. Sheet of Plexiglass cut to shape with a jig or scroll saw, attached with Velcro dots works well, cheap. BMW HL's are PRICEY !!!
All the frontal zone impact covers are designed primarily for "acidic insect leftovers" seal protection.  NOT really an issue if you wipe them down periodically.
Gary
Williamsport,Pa
2005 F 650 GS
« Reply #7 on: February 04, 2012, 12:03:52 PM »
I had the Trax and my seals lasted a year with them on so when I did the seals the boots went back on. I don't like doin' the seals. Damn little clippy thing takes all the fun out of it for me. YRMV
Offline TaosBrick
  • RedHotMotoBricker
« Reply #8 on: February 04, 2012, 09:13:56 PM »
Thanks for all the beta, everybody. DRx makes good points, the major thing around here is indeed that piece of gravel or rock from a truck that could chip or even dent the tubes. I'm likin' the plexi-headlite cover idea too.  The Traxxion solution looks good, seems it would deflect the hits where it really counts, for that coupla three or four inches above the seal, and the price is way right. Thanks Johnny  :2thumbup:
Thanks for the additional pics of the FB, FD. I dunno, I think I like the look of the c fairing best. I've always been partial to naked or nearly naked motorcycles. Just me, I suppose. I like the idea of the paralever, but always find myself suspicious of anything that involves a rubber boot. I've had to replace too many cv boots/joints over the years. Cool stuf!
- Samurai Maxim
Offline TaosBrick
  • RedHotMotoBricker
« Reply #9 on: February 04, 2012, 09:29:03 PM »
Jest checked out the Traxxion Dynamics website, they want 18.95 :yow to ship those leetle, nearly weightless pieces o plastique. I wrote 'em an email and said, huh? you gotta be kidding me. $7 for priority mail to my PO Box and you got a deal. Sheesh.
- Samurai Maxim
« Reply #10 on: February 04, 2012, 10:43:41 PM »
The fairings are swappable in short order.  The reason I decided on the K11RS fairing is that my knees FREEZE in the cooler fall/winter/spring temps here.  I'll swap on the C fairing for fair weather use in the warmer months.  It'll now be the FBC - Frankenbike Convertible..... :2thumbup:
That boot is nothing.  They don't wear out and, if they do, are fairly easy to replace.  It ain't no CV joint.
In a dusty environ I'll think you'll be better off with the Trax units.  Johnny had boots for a while and LOTS of dusty crap built up in there.  You need to have breather holes in them and in the dust they'll suck it right in.
Offline TaosBrick
  • RedHotMotoBricker
« Reply #11 on: February 04, 2012, 10:48:01 PM »
I get you on the freezin' knees FD, that's when it's time to bust out the SKIS! :yes Still no good weather for Brickin' around here yet, snow is flyin' as I write these lines, possible powder day en Mańanna - yea!
- Samurai Maxim
« Reply #12 on: February 04, 2012, 10:51:17 PM »
It also doesn't hurt to oil your forks lightly now and then.  Many times pitting is caused by rust, especially if you're near the ocean where the air is salty.  (Not an issue in Taos, I know.)
« Reply #13 on: February 04, 2012, 10:57:41 PM »
i wipes downs my forks with automatic transmission fluid... atf conditions the seals and its yeeeeehaaaaaaa...
i switched to traxxion cause my motobrick sits in a parking lot under a moto cover and when the santa anna winds blow my gaters would collect sand and f with my seals...
Offline DRxBMW
« Reply #14 on: February 06, 2012, 08:36:58 PM »
Thanks for that tidbit of information Taos.
Any word on the shipping charges yet ?
Ya,$18.95 is OUTRAGEOUS !!!   Reminds me of a ebay scam. BTDT
I'm going to call them on Tuesday morning see what the real story is.
Gary
Williamsport,Pa
2005 F 650 GS
Offline Uffda
« Reply #15 on: February 06, 2012, 09:18:12 PM »
I had the same reaction to their policies.
Figured it was time to add a little protection to my bike's naked forks.  Went to the site, expected to buy, and then stopped cold when their ridiculous shipping charge came up.
  • New England
  • 1995 K75RT
Robert
Offline Lawrence
« Reply #16 on: February 06, 2012, 10:52:14 PM »
Sand is able to blow in the gaiters through the tiny holes in the bottom that allow their expansion/contraction when the bike is underway?  Are you kidding me?  :loopy:
What part of the Atacama do you live in?
1985 K100RS
1982 Laverda Mirage 1200TS
1983 BMW R100RS
Offline TaosBrick
  • RedHotMotoBricker
« Reply #17 on: February 06, 2012, 11:03:54 PM »
Where I live in New Mexico, we have the finest, windblown dust that permeates everything. I've wrapped up engine blocks and other
parts with plastic sheeting and duck (not franken) tape, sealed plastic bags, etc. and the shit gets IN. So I'm with FD and JO on the fork boots full o crap theory.
- Samurai Maxim
Offline TaosBrick
  • RedHotMotoBricker
« Reply #18 on: February 06, 2012, 11:11:25 PM »
Got this nice little note in reply to my email to Traxxion:
Dan Anderson dan@traxxion.com2:01 PM (7 hours ago)
Charlie,
We generally use Fedex or UPS. Fedex's posted rate to your address is
$16.27, and we add a small handling charge to pay for the box and materials.
We can ship via USPS Priority mail 6-10 day service for $9.95. Just place
the order normally, and mention "ship via USPS" and I will take care of it.
Dan
Now that I can live with!
- Samurai Maxim
« Reply #19 on: February 06, 2012, 11:12:49 PM »
Gaiters are constantly expanding/retracting as the forks move up and down while you ride.  If you're in a dusty/sandy environment with lots of sand/dirt in the air then it will get sucked in on expansion.  Not sure why that's hard to understand.
Offline TaosBrick
  • RedHotMotoBricker
« Reply #20 on: February 06, 2012, 11:16:30 PM »
Gaiters are constantly expanding/retracting as the forks move up and down while you ride.  If you're in a dusty/sandy environment with lots of sand/dirt in the air then it will get sucked in.  Not sure why that's hard to understand.
Yah, kinda like a squeezbox - not the kind that mama's got either ; )
- Samurai Maxim
Offline DRxBMW
« Reply #21 on: February 07, 2012, 12:08:43 PM »
Charlie,
Dan
OK, I call and place a order this afternoon.
Thank you Taos for the legwork.
Gary
Williamsport,Pa
2005 F 650 GS
Offline DRxBMW
« Reply #22 on: February 07, 2012, 02:19:45 PM »
Charlie,
Dan
Talked with Dan in person, my Traxxion protectors are in the mail.
Suggested they offer "shipping choices" on there website cart.
Gary
Williamsport,Pa
2005 F 650 GS
Offline Lawrence
« Reply #23 on: February 07, 2012, 02:52:51 PM »
In the 48 years I've lived in an arid, semi-desert environment I have never found sand in any fork gaiters.  Seems like those are enough data points to convince me that I have other things over which to worry.
I guess BMW riders will be BMW riders, eh?   :lol:
1985 K100RS
1983 BMW R100RS
Offline DRxBMW
« Reply #24 on: February 10, 2012, 04:25:18 PM »
Charlie,
Dan
Traxxion protectors arrived in the mail this afternoon.
GIANT box, NO wonder they wanted to charge close to $19.00 for UPS shipping.
Why in the hell they required such a BIG box is a mystery to me. The actual product is small in size.
Anyway, I'll install them Saturday morning and report back. Plan is experiment with a height extension similar to the Touratech model guard.
Were supposed to get snow tonight according to the weather channel.  :dunno2:
GREAT ride this afternoon, GS is pathetically bathed in mud from head to toe. .  :bmwsmile :bmwsmile
Gary
Williamsport,Pa
2005 F 650 GS
