Good morning folks! Indeed, as some of you suspected, it appears to be right handlebar control. Disconnected it and the left turn signal stays on (latching). I disassembled the right hand control and tried to clean contacts as best as I could with electronic part cleaner spray and 1200 grit paper, but still the same. In fact, while kill switch works, starter button doesn’t work (no crank). But I am getting crank when jumping its leads (solid green and black/green, I think). So I created external loop with push button switch I found in my garage and it works for starting engine. So I am thinking to add similar external loop to bypass cancellation paddle, just not sure how to do it.
