Author Topic: Removing instrument cluster from K75C  (Read 4830 times)
Offline 3dachshunds
« on: June 13, 2026, 02:04:11 PM »
I finally found K75 in bad enough shape not to feel guilty about using for a scrambler built. I can’t remove the plug from the cluster, as if something is holding it in place (1994 k75c). It just popped out on 85 k100rt I did earlier. Thank you!
* IMG_2146.jpeg (48.45 kB . 768x576 - viewed 253 times)
  • USA
  • 1992 BMW K75, 2013 Triumph Tiger 800 roadie
Re: Removing instrument cluster from K75C
« Reply #1 on: June 13, 2026, 05:05:29 PM »
That's a photo of the connector cover. The connectors are beneath it. Was the screw attaching the cover easily removed?
Offline 3dachshunds
« Reply #2 on: June 13, 2026, 05:11:02 PM »
There never was a screw, the cover slides off.
* IMG_2153.jpeg (56.05 kB . 768x576 - viewed 297 times)
  • USA
« Reply #3 on: June 13, 2026, 05:30:36 PM »
There is a screw stub in that hole or there was a screw in that hole. The covers on the K75 are screwed on.
Go to this link. Your Brick has the earlier cover setup discussed in 3b of the K75 Standard instructions above the 75C instructions. It can be troublesome to remove. Covers remove by being pulling upward after the screws are removed. Have you removed this cover previously?
Offline 3dachshunds
« Reply #4 on: June 13, 2026, 05:36:10 PM »
No, I haven’t removed the cover previously, just unbolted lunch box from the bracket and that’s how it looked. Thank you for the link!
  • USA
« Reply #5 on: June 13, 2026, 05:45:28 PM »
If there's no screw in there, it's just stuck. Lube it with spray silicone or electronic cleaner along its edges, tap it gently around its perimeter, and patiently wriggle it off with pliers if necessary.
« Reply #6 on: June 13, 2026, 07:03:44 PM »
Use this link to view an instrument cluster wiring guide.The photo below is a 75C connector of similar vintage. Note the screw protruding.
Offline 3dachshunds
« Reply #7 on: June 13, 2026, 07:14:38 PM »
Great, thank you!
  • USA
Offline Edward
« Reply #8 on: June 14, 2026, 08:34:57 PM »
Lift straight up will help prevent binding.
  • USA
  • K75s 1987 Original owner
Offline 3dachshunds
« Reply #9 on: June 14, 2026, 08:46:15 PM »
It finally came out with a help of channel pliers, as Laitch suggested. Thanks everyone!
  • USA
