Author Topic: Intake boot clamp source?  (Read 4523 times)
Offline schrocketeer
« on: September 10, 2025, 01:43:28 PM »
May I please have source recommendations to secure the rubber boots between the airbox and throttle bodies?
I'd rather not go back with the OEM Oerliker clamps, since they seem to be one-time use.
As I measured last night, the worm clamps need to be 7mm wide, and 42mm for one side, and 50mm for the other.
Didn't check carefully enough when I ordered these, since they're 12mm wide: https://www.amazon.com/dp/B0CJV9BBJ7?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
FYI, zip-ties/tie-clamps can leak, and look like lots of other problems, sending you on a wild goose chase. Ask me how I know. :-\
  • North Alabama
  • 1985 K100RT very original
Ken
Re: Intake boot clamp source?
« Reply #1 on: September 10, 2025, 04:03:51 PM »
https://www.mcmaster.com/54195K32/ looks to be a good candidate.
  • North Alabama
Ken
Offline Kaos
  • Vlad the Extractor
« Reply #2 on: September 10, 2025, 05:26:35 PM »
T-bolt hose clamps, stainless. Also aestheticly more appealing.
Or Google for intake manifold clamps and the wanted mm's
  • Basically Everywhere
« Reply #3 on: September 10, 2025, 08:55:35 PM »
If you put the worm drives on the back you get a very clean look.
Offline lewisnort
« Reply #4 on: September 11, 2025, 05:11:53 AM »
SKU FUA60940-2 from motorworks are what I used thought that can get a bit pricey and most certainly cheaper from somewhere else since they're just generic clamps.
  • UK
  • 1998 K1100 LT
« Reply #5 on: September 12, 2025, 04:26:42 PM »
The clamps from McMaster-Carr came today, 10 pack was $20.01. I have two Bricks that need new clamps, so got 2-10 packs. With shipping it was $54 in the US.
Pictures show the box they came in, if you want to source separately. Also attempted to show the fit in the upper and lower boot slots.
Descriptor
https://www.mcmaster.com/catalog/131/330/54195K32
Worm-Drive Clamps for Firm Hose and Tube
305 Stainless Steel Screw, 5/16" Band Width, 1-11/16"-2-1/4" Clamp ID
54195K32
  • North Alabama
Ken
« Reply #6 on: September 14, 2025, 05:19:14 AM »
48mm Suzuki band clamp part number 09402-48208 for TB->bushings and bushings->air plenum connections
.  perfect fit.
