Author Topic: K1100 Drive shaft knock.  (Read 5778 times)
Offline Shinybeast
« on: August 17, 2025, 05:03:59 PM »
Hi,
It started with the seal breaking on the final drive.  On inspection it turned out that the bearing had shredded and caused a leak.
Swapped that over, and changed the final drive and swing arm bearings.  All running great and smooth as silk, but when I run the bike stationary, ther's an intermittenk knock somewhere between the gearbox and the final drive.  Driveshaft is all solid and the 'ears' are set right so it's not unbalanced.  All splines lubed with Moly grease.  All fluids in good order.  75-w140 in the gearbox as well as Liqui Moly additive. 75-w90 in the final drive.
Is this ok?  Can't feel it at all when I'm riding.
  • Liverpool
  • K1100 LT
Re: K1100 Drive shaft knock.
« Reply #1 on: August 17, 2025, 05:20:21 PM »
How many miles on it?
Offline Shinybeast
« Reply #2 on: August 17, 2025, 05:54:21 PM »
  • Liverpool
  • K1100 LT
« Reply #3 on: August 18, 2025, 09:04:28 AM »
Was that flange nut being used on the pivot pin in the photo before this repair?
Offline Shinybeast
« Reply #4 on: August 18, 2025, 11:55:01 AM »
Hi Laitch,
It's not a flange nut, one side is a fixed pin and the other (the side you can see) is adjustable).  The pin on that side it tightened up relatively loosley, so the final drive is almost supported,  then the ring nut is torqued up tight.  I've upgraded to a set of motorworks' bearings which are easier to grease, but the only torque spec is "don't over tighten", hence why I've marked it to make sure it doesn't loosen off.
Here's the upgraded part...
https://www.motorworks.co.uk/final-drive-pivot-bearing-upgrade-kit-tra11092-1.html
  • Liverpool
  • K1100 LT
« Reply #5 on: August 18, 2025, 12:50:11 PM »
That's called a flange nut over here, anyway. I guess we're still separated by a common language.  :laughing4-giggles:
I didn't recall that aftermarket assembly, but it seems popular with those who have installed it. Anyway, I'm more accustomed to seeing an OEM plain nut locking the pin. It's frustrating to finish a job and have a glitch like that. If it isn't the bearing associated with that adjuster assembly at the root of this, more disassembly could be necessary.
Offline natalena
« Reply #6 on: August 18, 2025, 06:17:32 PM »
Sounds sort of like the bevel gear isn't meshing smoothly without some pressure from the driveshaft. I don't have an 1100, so this is all nonsense, but were washer/shim parts removed from the bearing replacement?
Good luck
  • MST
Offline Shinybeast
« Reply #7 on: August 19, 2025, 07:01:10 AM »
Hi Laitch,
The nut is similar but there's no flange, just a symetrical flat ring nut.
* Screenshot 2025-08-18 at 19.40.53.png (431.39 kB . 432x576 - viewed 527 times)
  • Liverpool
  • K1100 LT
Offline Shinybeast
« Reply #8 on: August 19, 2025, 07:08:33 AM »
Good luck
Hi Natalena,
Thanks for your suggestion.
There's a shim in the assembly but that's all safely back where it came from.  The manual has some info about reinstalling, but, as usual, it's a bit confusing.
I might have another look at it.
* Screenshot 2025-08-19 at 12.05.29.png (50.49 kB . 571x576 - viewed 540 times)
  • Liverpool
  • K1100 LT
« Reply #9 on: August 19, 2025, 10:01:38 AM »
Hi Natalena,
Thanks for the photo of the nut. The prior photo looked like it was flanged.
How did you decide shim thickness, or did you just use what you had?
Offline Kaos
  • Vlad the Extractor
« Reply #11 on: August 19, 2025, 01:02:48 PM »
But if its knocking, have you asked it to stop doing so?
Anyway. I think it might be helpful if you let it idle in neutral and check up close where the knock is coming from.
  • Basically Everywhere
Offline Shinybeast
« Reply #12 on: August 19, 2025, 02:59:57 PM »
  • Liverpool
  • K1100 LT
Offline Shinybeast
« Reply #13 on: August 19, 2025, 03:01:32 PM »
Hi Kaos,
It's only an issue when it's turning the shaft and final drive.
  • Liverpool
  • K1100 LT
Offline Shinybeast
« Reply #14 on: August 19, 2025, 03:10:02 PM »
Hi,
I foolishly assumed that BMW would put the right thickness shim in there to start with.
Now I've investigated a bit it looks like this is a common cause of shredded bearings.
  • Liverpool
  • K1100 LT
Offline natalena
« Reply #15 on: August 20, 2025, 01:06:46 AM »
Motobins is great for parts. Cheers
  • MST
Offline Shinybeast
« Reply #16 on: August 20, 2025, 04:54:40 AM »
Hi Kaos,
I've used Motobins a lot over the years and their service is great, but I usually find that Motorworks is a bit cheaper.
  • Liverpool
  • K1100 LT
« Reply #17 on: August 20, 2025, 11:10:26 AM »
Hi,
It's likely that shims of different thickness are available to accommodate production variations or wear. Your makeover and the concomitant wear after years of use changed clearances. It also could be that the most common cause of shredded bearings is lack of regular lubrication.
Offline Shinybeast
« Reply #18 on: August 28, 2025, 03:29:10 PM »
Hi Laitch,
It's all back togeteher again now, looks like I got the shim from the old part and the replacement mixed up.  They look identical, though having now learned the importance of the thickness, I measured them both and it turns out there's a 0.2mm difference.  I disovered another method of testing the preload, the "drag method'.  I thought that the drive should just spin free but apparently there should be 1.1-1.8NM drag.  Once I put the right shim back there was some resistance when I tried to turn it, but not too much. Now it's back together and there's no knock.  I'll call into my local bike shop and get them to test it properly later this week as I don't have a torque meter that can measure that low.
Also, I must apologise.  I discovered that it is indeed a flange nut on the bearing.
* IMG_1721.jpeg (40.69 kB . 768x526 - viewed 534 times)
I'm guessing they've added this because the new bearing doesn't come with a pre set torque, just says "don't over tighten". The original pins had to be torqued to 150 and 105Nm.  I've torqued the new pins to 80Nm and marked them to show any loosening.  Maybe the flange is to give a greater reistance by having a bigger surface area?
  • Liverpool
  • K1100 LT
