Author Topic: radiator hose life?  (Read 46501 times)
Offline gard
radiator hose life?
« on: May 06, 2025, 08:18:02 AM »
1985 k100 RT with 142,000 miles. The bike appears to have original hoses, I did not see any obvious cracks or soft spots when I replaced the radiator fan.  Still wondering if I should replace all the hoses while the fairings are off. Have others found they seem to last forever or have you gotten stranded? I noticed the hose behind the radiator is collapsed when bike is cold, it regains its round shape if the fill cap is removed. Is this normal due to the vacuum in the cold system which pulls fluid from the overfill tank or a sign of impending failure?
  • Vermont USA
  • 85 K100RT
Re: radiator hose life?
« Reply #1 on: May 06, 2025, 08:24:07 AM »
If you don't replace the hoses now when the fairing is off, you'll never have any peace, gard.  :laughing4-giggles: Get on it! It isn't a big deal.
Offline Kaos
  • Vlad the Extractor
« Reply #2 on: May 13, 2025, 09:12:20 AM »
you can also get pretty colours for your collant hoses too!
Who needs fairings when you have red coolant hoses. It will run faster too!
  • Basically Everywhere
Offline gard
« Reply #3 on: May 16, 2025, 04:59:28 PM »
Thanks for that, I found the various color ones on the ebay, its strange on the same search on a different day comes up with a different result.
Ordered the red as recommended, I want those extra hp
zap bmw k100 silicon hose
  • Vermont USA
  • 85 K100RT
Offline Past-my-Prime
« Reply #4 on: May 18, 2025, 01:55:00 PM »
For group wisdom: does collapsing coolant hose indicate problem with radiator cap? As in: it will let the high pressure coolant out but won’t bring it back from the reservoir?
Offline Duckbubbles
« Reply #5 on: May 18, 2025, 06:58:52 PM »
Collapsed hoses are caused by a vacuum in the system- more than likely radiator cap related.
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'85 K100/1100RS 40 years, 331,000 mi.
'23 R1250RS
'03 R1100S BCR #6/200
500,000+ BMW miles
Offline gard
« Reply #6 on: May 19, 2025, 08:04:07 AM »
It makes sense that the collapsed radiator hose would be related to the radiator cap, not sure why I did not think of that. Can it be cleaned, repaired and tested or is it one of those items where you just replace it?
On a related note I ordered the new red silicon hose set (less than $60) but somehow forgot to check where it was coming from (China) so no idea when it will get here. The hose set did not include the overflow tube, about another $20. IIRC it was north of $200 from BMW.
  • Vermont USA
  • 85 K100RT
« Reply #7 on: May 19, 2025, 04:25:14 PM »
Make a temporary mark of the coolant level when the engine is cold, then again when the engine is warm. Next morning it should be back at the cold level, then back again to the high level after a ride. If not, another possibility, but unlikely, is the overflow hose is blocked.
If the radiator hose looks a bit swollen or feels too soft, it's too weak to resist the vacuum and should be replaced (It shouldn't be too hard either, like if it goes snap, crackle and pop when you squeeze it, small pieces of rubber could have broken off and started circulating in the coolant, causing a blockage somewhere) I have five bricks, none of them have radiator hose problems, and most of them have had heaps of use and abuse.
Sometimes I think I should replace that part with one that uses a normal radiator cap, then I could easily use my pressure tester.
Normally you would just replace the radiator cap. Finding out the price of one of these BMW caps is something I wouldn't be looking forward to.
« Reply #8 on: May 19, 2025, 05:22:51 PM »
It could be worn hoses are the problem. It could be radiator cap gaskets. It could be the radiator cap itself; in Germglish the cap is apparently called "a lock". Photos are from the MaxBMW parts fiche.
« Reply #9 on: May 19, 2025, 05:28:30 PM »
FYI: As Max shows, the last time I purchased a radiator cap from BMW it came with the gaskets so I did not need to buy them separately.
« Reply #10 on: May 19, 2025, 09:01:03 PM »
If the coolant level goes higher and lower, let's say about an inch, with temperature changes, the radiator cap and overflow hose seem to be good, then the hose is probably too weak.
If this brick has been sitting for years and you're just getting it back on the road, it could be that the valve in the radiator cap is stuck in the closed position. There are two valves, both should be in working condition. One allows coolant into the expansion tank, and should be closed at other times. The other allows coolant to return, and should also be closed at all other times. This is the one with the question mark over it. Check that it lifts up, and that it closes when let go. While you're at it, check that the other valve opens when you press down on it, and that it returns to the closed position when you let it go.
« Reply #11 on: May 20, 2025, 01:15:02 AM »
OTOH: $12.00 worth of gaskets could possibly solve the problem without the buying the cap. Consider it courting the thrill of low-stakes gambling.
Offline gard
« Reply #12 on: May 22, 2025, 07:20:54 AM »
I decided to try door #3, bought a used cap complete with the neck, hose and hose clamp for less than $10. I disassembled the cap, the center section just snaps out, it was all pretty clean and free but I soaked it overnight in vinegar anyway. The gaskets look good. I will install it along with the new overflow rubber tubing which is on order, on the slow boat from China.
Now I have a spare neck I could make a radiator cap tester, not sure what pressure it should relieve at or what vacuum level for the return.
  • Vermont USA
  • 85 K100RT
« Reply #13 on: May 22, 2025, 10:30:11 AM »
. . . not sure what pressure it should relieve at or what vacuum level for the return.
Why is that? Not enough fresh air and shredded wheat in your youth?
From the miracle of the talking leaves within the BMW K75 K100 2V manual downloadable from the world famous MOTOBRICK.COM. from this list.
Reservoir tubing could have come from any auto parts like NAPA or Baileys. You could have gotten by bicycle if you wanted it to take more time getting there.
 :laughing4-giggles:
« Reply #14 on: May 22, 2025, 12:10:05 PM »
Bicycles are easier to pick up, albeit somewhat slower fetching rubber hose.
« Reply #15 on: May 22, 2025, 12:16:26 PM »
It looks so comfortable, it would be a shame to disturb it.
Offline gard
« Reply #16 on: May 22, 2025, 03:09:28 PM »
 :laughing4-giggles:
Why is that? LOL Well I was just finishing my favorite IPA and it was raining outside and the hardcover book is out in the barn with the bike and I was too lazy to go look. I have tried downloading the official 2V version a couple of times but have each time gotten some kind of error message. Not sure what that is about.
I guess I could read from that table that the pressure relief should be between 1 and 1.15 bar, (about 15 psi).
Thanks for the table, I thought I had read someplace it was 10 psi.
I still do not know at what vacuum level the return should open up at.
  • Vermont USA
  • 85 K100RT
« Reply #17 on: May 22, 2025, 04:55:09 PM »
Data from a source that cannot be identified closer than "somewhere" is nowhere.
« Reply #18 on: May 23, 2025, 11:28:47 PM »
From the Clymer manual, the pressure relief valve opens at 100-114 kPa (14.5-16.5 psi)
The vacuum valve opens at 10.34 kPa (1.5 psi) but these vacuum numbers should have a minus sign in front of them.
If the valves are closing under spring pressure, and the coolant level is changing as it should, that should be ok.
« Reply #19 on: May 24, 2025, 09:26:00 AM »
Minus signs are unnecessary because the word vacuum itself expresses a state of being below atmospheric (or ambient) pressure. High quality vacuum gauges don't have minus signs and pressure gauges usually don't have plus signs.
« Reply #20 on: May 24, 2025, 10:39:42 PM »
Ok, I'll take the bait, so now we're looking at the minus sign. So now I've looked at four brick books I have, Clymer's BMW, Haynes, and the Rider's Handbook. They all have a minus sign, except for Clymer's. You're right, we should all be aware that it's negative, then the minus sign would be unnecessary. So that's a lot of waisted ink there, one more first world problem.
« Reply #21 on: May 24, 2025, 11:16:46 PM »
It really sucks. :laughing4-giggles:
« Reply #22 on: May 25, 2025, 08:58:25 AM »
You're right; they do. I should be more positive than negative. Pray
Offline Kaos
« Reply #23 on: May 25, 2025, 12:37:51 PM »
Why would you take a picture of a motorcycle cover on the pavement without a motorcycle?
Offline gard
« Reply #24 on: May 25, 2025, 04:53:09 PM »
I got some more work done on the bike. I replaced the alternator monkey nutz, it went pretty easy, I made a couple of long pins to guide it back on with a mark on the alternator to align to the gap nutz. The old ones had some wear and there was black greasy powdered rubber like crap under the alternator. The rear battery tray vibration mounts were free from the transmission so I drilled and tapped the holes to 5/16-24 and made a couple of helicoil type inserts with the 6x1 mm thread in the inside and 5/16-24 on the outside.
* KIMG2759.JPG (53.38 kB . 768x576 - viewed 441 times)
* KIMG2761.JPG (46.34 kB . 768x576 - viewed 466 times)
* KIMG2762.JPG (39.78 kB . 768x576 - viewed 450 times)
The ebay used radiator cap and neck with hose arrived so I attached it to some gauges to check. I slowly increased the pressure and both caps release pressure at about 16 psi. When I close the valve and the pressure drops to about 9 psi in 6 seconds then slowly drops to about 5 psi over the next minute. The book says it should hold the 16 psi for 6 seconds so it is out of spec. Not sure if this will cause any big problem. The original cap had a swollen inner gasket that would not stay in place so I swapped the ebay one back and forth.
* KIMG2777.JPG (42.63 kB . 768x576 - viewed 452 times)
* KIMG2780 (1).JPG (49.48 kB . 768x576 - viewed 484 times)
I also checked the vacuum relief valve with a hand vacuum pump and a digital meter that is set to the psi range. The valve opens around 1 psi. When I stop pumping the vacuum drops to zero within about 30 seconds. So nothing about the radiator cap would explain the collapsed radiator hose.
* KIMG2771.JPG (41.53 kB . 768x576 - viewed 467 times)
I did find some smutz in the overflow hose which was also very soft, I cleaned everything and installed a
new hose. I guess I will hook the gas tank up, adjust the throttle bodies and go for a ride if it stops raining.
Any opinions on if I should spring for a new cap?
  • Vermont USA
  • 85 K100RT
