Author Topic: Fuel pump. Low voltage. k1100  (Read 4513 times)
Offline Areshuan
« on: April 20, 2025, 03:32:33 AM »
Hello !
The pump is healthy. It works perfectly when applying 12 volts directly to the pump or when using the fuel sender wires.
The voltage at the socket reads 13 v.  but when i connect it to the fuel sender socket it does this thing.  Voltage around 6 v. And erratic functioning.
I swtiched some relays and its the same story.
https://www.youtube.com/shorts/KeSQ57i2sj4
Any ideas?  Thank you
  • Ecuador
  • 96 K1100RS
Killing time until time kills me
96 K1100RS
07 R1200GS
04 R1150GS
Re: Fuel pump. Low voltage. k1100
« Reply #1 on: April 20, 2025, 05:58:48 AM »
Sounds like an issue with the "pass-thru" function of the fuel level sending unit assy that is mounted to the underside of the fuel tank.
It isn't common for this to fail, but it is not unheard of either.
I'd suggest looking for a good used one.
1995 K1100LT 0302044 (R.I.P)
Offline Areshuan
« Reply #2 on: April 20, 2025, 01:32:46 PM »
I change the fuel sender wires and  connectors. It works perfectly as shown in the video.
But as soon as I put it together with fuel i got the same problem.  I have no idea what to do next .
https://www.youtube.com/shorts/8o_9Geh8PWI
  • Ecuador
  • 96 K1100RS
96 K1100RS
07 R1200GS
04 R1150GS
Offline Areshuan
« Reply #3 on: April 21, 2025, 01:39:17 AM »
It was a loose ground cable !
  • Ecuador
  • 96 K1100RS
96 K1100RS
07 R1200GS
04 R1150GS
« Reply #4 on: April 21, 2025, 08:46:04 AM »
 103123
Tags: #fuelpump
