Fuel pump. Low voltage. k1100
Topic: Fuel pump. Low voltage. k1100 (Read 4878 times)
Areshuan
Motobrick Curious
April 20, 2025, 03:32:33 AM »
Hello !
The pump is healthy. It works perfectly when applying 12 volts directly to the pump or when using the fuel sender wires.
The voltage at the socket reads 13 v. but when i connect it to the fuel sender socket it does this thing. Voltage around 6 v. And erratic functioning.
I swtiched some relays and its the same story.
https://www.youtube.com/shorts/KeSQ57i2sj4
Any ideas? Thank you
Ecuador
96 K1100RS
Killing time until time kills me
96 K1100RS
07 R1200GS
04 R1150GS
Scott_
Administrator
Re: Fuel pump. Low voltage. k1100
Reply #1 on:
April 20, 2025, 05:58:48 AM »
Sounds like an issue with the "pass-thru" function of the fuel level sending unit assy that is mounted to the underside of the fuel tank.
It isn't common for this to fail, but it is not unheard of either.
I'd suggest looking for a good used one.
My Garage
Areshuan
Motobrick Curious
Reply #2 on:
April 20, 2025, 01:32:46 PM »
I change the fuel sender wires and connectors. It works perfectly as shown in the video.
But as soon as I put it together with fuel i got the same problem. I have no idea what to do next .
https://www.youtube.com/shorts/8o_9Geh8PWI
Ecuador
96 K1100RS
96 K1100RS
07 R1200GS
04 R1150GS
Areshuan
Motobrick Curious
Reply #3 on:
April 21, 2025, 01:39:17 AM »
It was a loose ground cable !
Ecuador
96 K1100RS
96 K1100RS
07 R1200GS
04 R1150GS
Laitch
Faster than a speeding pullet
Administrator
Reply #4 on:
April 21, 2025, 08:46:04 AM »
Along the Ridley in Vermont.
1995 K75 102,000 miles
#fuelpump
