Author Topic: 1995 K75 Rehab after 32K miles  (Read 84725 times)
Offline Cinderedblock
  • Caveman
« on: April 09, 2025, 07:41:53 AM »
I have been working on replacing my clutch and the inside of the bell housing didn't show any signs of oil. After removing the clutch housing  oil started to slowly seep out.
Im assuming my seal has failed, I wanted to see it wouldn't leak with the housing back in but I don't have a good way to test it.
  • Somewhere in the Carolinas, just follow the trail of oil.
1995 Silver K75 32,000 miles
1995 Red K75 18,000 miles -FS
2007 KLR-650 "Pipe Bomb"  -Previously wrecked and ready for round two
2023 BMW G310R - For getting to the auto parts store
Re: 1995 K75 Rehab after 32K miles
« Reply #1 on: April 09, 2025, 09:51:59 AM »
Welcome to the site!
How long have you owned the K75 that's getting the clutch replaced; how many miles are on the odometer and how many of those miles have you ridden it? What was the purpose of removing the clutch housing? An oil-free intermediate flange indicated the seal and o-ring were okay. For a clutch replacement, the clutch housing usually stays put. Removal of the housing may have compromised the seal or o-ring. What was the oil level in the crankcase before this adventure began?
Running the engine while riding the Brick is the leakage test most of us use; we discover leakages usually after an enjoyable ride.  :laughing4-giggles: Leakage generally happens before repair or replacement of parts is undertaken, unless a complete rebuild is being done; then leakage happens after reassembly, usually during another enjoyable ride. Drops, streams or pools of oil on the engine case or pavement afterwards is the way most of us learn about leakage from engine component seals and o-rings.
I recommend replacing the shaft o-ring and the seal right now. They will be effective for tens of thousands of miles if they are installed carefully in conformance with established procedures.
  • Caveman
« Reply #2 on: April 09, 2025, 10:18:42 AM »
The odometer stopped working 2 owners ago set at 18k. The owner I bought it from had it serviced by a mechanic and rarely rode it. I probably have only ridden it 400 miles bringing it home and riding around. On my return trip the bike started bucking and it wasn't the engine. I had to do a clutch adjustment on the road to get it going again. I had maxed the adjustment bolt out and it only bought me the next 200 miles. Before my trip I had to adjust the cable tension, the engine wasn't disengaging making it hard to shift. That's why he never noticed, the clutch was so far adjusted in it didn't slip but it was shot.
No Freeplay in the lever, the bucking was the bike disengaging and engaging the engine. Disengaging the clutch and the engine would rev normally and it would buck in any gear.
I was just following the clymer manual, without knowing the state of the bike and that the clutch must have went through its lifetime I figured I should lubricate the housing splines as the manual explained and get an idea of what I'm working with.
They were bone dry but not worn thankfully everything looks great in here. It was a bit hard to get out on account of the absence of grease. I'm referring to page 196 (figure 22 and 23). Im not just doing the friction plate, Im installing a full kit.
This is my first clutch replacement so I thought I should do a full service. I've been praying that by taking out the housing the seal has nothing to seal against but I guess the only way to test is to put more oil in and reattach the starter and see if it leaks before fouling my new clutch kit. I drained the old oil to stop the leak because the oil change was next anyway.
« Reply #3 on: April 09, 2025, 12:31:38 PM »
You've lost me. It seems like you're over-thinking this.
A functioning rear main seal assembly shouldn't be leaking regardless of whether the crankcase is full or half-full before you install the clutch housing, and it shouldn't leak after the housing and its o-ring are installed and torqued. Starting the engine after assembling the clutch wouldn't prove much to me if the transmission and rear drive weren't putting a full load on the assembly by taking me the twenty mile to Morse Farm for a maple creemee. I've not observed anybody testing like you propose after rear main seal, o-ring and clutch housing and clutch pack installation. Maybe it's a well-kept secret part of the procedure. or I'm speed-reading too fast. Regardless, please update Motobrick with your progress.
Good luck with your Brick. 112350
  • Caveman
« Reply #4 on: April 09, 2025, 12:54:44 PM »
I'm overthinking it, the seal should never have leaked. I probably broke it trying to work the housing out. I'm just incredibly reluctant to order the seal. I've went ahead and put it on rush order.
I just hope that was the only issue. Since this is my first time in a K75 clutch I was just rethinking some of the things I observed. I never pinpointed exactly where the oil was coming from, I just assumed it was the seal.
When I replace the seal I assume I should test it first before putting anything back in, wouldn't that require the oil pump coming on to get oil to that part of the engine?
Picture is before I took the clutch housing out.
« Reply #5 on: April 09, 2025, 02:21:39 PM »
One of my workshops looks just like that but it's covered with snow right now. More or less dry ground is possible relatively soon, July maybe!
I'll try again: I wouldn't waste my precious time by trying to test that assembly unless the test was happening in a my speeding Brick taking me somewhere else other than to a pile of shop rags and tools.
« Reply #6 on: April 09, 2025, 06:13:57 PM »
I really can't confirm one way or the other with the k75's as I've not owned one, however.... with the 1100's if the oil level is ABOVE the center dot/middle of the sight glass, the oil will leak out if you pull the clutch basket.
  • Caveman
« Reply #7 on: April 09, 2025, 07:14:43 PM »
That's what I was wondering. I can't really risk having to disassemble this again. All the clutch fasteners are single use so Im going to try replacing it before closing up and see what happens. It's worth the $100 rather than later I have reasoned. I'll just have to be very delicate with my installation. I don't want to make this worse.
Id like to run a test but as it's been pointed out thats mostly useless until tested under load.
If anyone else has any other instances of oil seeping out during basket remove please let me know.
« Reply #8 on: April 09, 2025, 08:50:32 PM »
I'm 99 percent sure you did not damage the seal when you removed the clutch basket. I believe Scott's point applies to the K100 too, as well as the K75. It didn't leak before you removed the clutch basket so it wasn't leaking. I'm pretty sure it leaked from above the top of the lowest part of the seal, which it will if the oil level is above it when the basket is removed.
There is a photo which shows what I'm trying to explain, in a recent thread by Filmcamera.
Sometimes the problem is just that the clutch cable is stretched.
I think they're being over cautious in describing the clutch fasteners as single use. One of the reasons being that thread locker was probably used, so if heating them up before removing, and then cleaning the threads, it's not an issue to worry about. I think it's safe to reuse them, regardless. Next time you lube the splines, you can check to see if any are loose.
Since the clutch basket is removed anyway, you might as well replace the seal and O-ring, and you probably won't have to go back in there for many years.
  • Caveman
« Reply #9 on: April 11, 2025, 10:59:40 AM »
The worrying thing is that should be common knowledge. I'm at the crossroads where I have installed and torqued the basket and waiting on my alignment tool. I can either finish installing the clutch then find out the hard way or dig back in and replace the seal when the seal arrives and I'm hesitant to do either. I already ordered a new round of clutch bolts and nut, I just have to decide.
It sounds like I'm either I'm wasting my time worrying about the seal or about to make a major mistake and have to go through all this again.
  • Caveman
« Reply #10 on: April 16, 2025, 10:33:42 PM »
After closing up and replacing all the fluids I took it for a ride. So far no signs of leaking or slipping. Brought it up to 110mph for a bit and so far it's alright. It has a vibration issue from the transmission back I need to address.
The drive shaft splines are worn but the final drive looks new so I'm going to order a replacement shaft ASAP before the final drive gets damaged. Hopefully that should be the source of the issue. If not it may be the final drive.
On the stand when I engage the wheel and it starts spinning it makes some noise and has a low frequency vibration. At first I thought it was an unbalanced tire but I'm really not sure. I should test the brake disk. I'll do some troubleshooting before posting about that.
« Reply #11 on: April 16, 2025, 11:20:18 PM »
I doubt those slightly worn driveshaft socket teeth are creating vibration.
Be sure the wheel bolts are tight and there is the correct amount of the correct weight oil in the transmission and rear drive. You can always pull the driveshaft from the swing arm to check the u-joint to be certain that it was snapped into place before you assembled the rear drive to the swing arm and inspect the u-joint for smoothness of movement.
If the wheel doesn't feel loose when you grab it on each side trying move it any direction except in rotation, the crown bearing within it is likely okay.
Offline triplek
« Reply #12 on: April 17, 2025, 08:37:31 AM »
I'm of the school if thought that say's, "If you’re deep in an engine, always renew maintenence parts in reach".
The rear main seal is one to preemptively replace if you have the clutch out. It's a cheap & easy job "today" when you have a hand on it.
"Every time you criticize my grammar, I like you a little bit fewer."
1995 K75 RTP, 1995 K75 RT, 1993 K75, two K75 frames, 1 fully assembled engine from airbox to exhaust tip and enough fairings and  parts to build another K. Soon.  ;)
« Reply #13 on: April 17, 2025, 09:51:09 AM »
I'm of the school that believes taking calculated risks by using something that seems to be working okay is exciting because I know I'll never be climbing K2 or flying by wingsuit. I'll accept the consequences, which will be considerably less than falling into a crevasse high in the Karakoram Range or embedding myself into the Precambrian gneiss of a mountain in Norway. It's probably a much cheaper thrill, too! 112350
Offline triplek
« Reply #14 on: April 17, 2025, 12:55:12 PM »
...much cheaper...! 112350
We are talking about the same 10 minute, $30 rear main seal renewal, yes?  :)
« Reply #15 on: April 17, 2025, 02:11:28 PM »
I wouldn't know about the 10 minute qualification because I haven't replaced mine in 90K miles, but I believe that seal is the subject. That's what makes it even more exciting!
You're discussing a cheap seal; I'm advocating a cheap, and almost daily, adventure.
  • Caveman
« Reply #16 on: April 17, 2025, 06:08:28 PM »
After replacing the clutch and doing some tests I thought I was done.
However
After riding in town in 2nd and keeping it reved (5-6K) up it started bucking again. With the bike in gear it pulls normally then the power gives out, then it will pick up again randomly.
I have no idea what is causing a loss of power to the rear wheel. It's not the engine, I can disengage the clutch and it revs fine. It does it in any gear. And if I stop and wait 10 minutes it will stop slipping for a very short time. Enough to get up to 85mph without issue until it begins again.
I can ride the friction zone and it will continue crawling forward without the sensation of a clutch slip. It just feels like the power it's being pushed with drops.
I am at my wits end with this problem.
« Reply #17 on: April 18, 2025, 07:29:40 AM »
Are you absolutely positive beyond the shadow of a doubt that your problem isn't in the engine and fuel delivery?
It takes almost no power to rev the engine with the clutch pulled in.  That, to me, doesn't prove a thing.
Have you checked the mundane stuff like the fuel filter in the tank and the fuel line hoses?  How is your fuel pressure regulator?  Is the fuel tank not venting properly?  Any air leaks?
  • Caveman
« Reply #18 on: April 18, 2025, 09:57:11 AM »
Very confident. The RPM doesn't drop but the power delivered to the wheel does.
It drove without issue for 2 days under heavy load.
I'm currently praying that grease sling onto the new plates so I'm opening it up again to clean them.
It started after I was riding in town in second and keeping the engine at 7k rpm so I have a feeling that would definitely sling grease.
« Reply #19 on: April 18, 2025, 10:40:43 AM »
So when you open the throttle in 4th or 5th gear, the RPM increases but the speed doesn't.
« Reply #20 on: April 18, 2025, 11:36:58 AM »
That could be the description of a slipping clutch. Sometimes a worn or oil-compromised clutch won't slip until higher revs are reached.
« Reply #21 on: April 18, 2025, 01:48:03 PM »
Now I read that you've already installed a either a new clutch or new clutch pack.
Readjust it by the book.
Offline triplek
« Reply #22 on: April 23, 2025, 02:50:20 PM »
...there's also the possibility that a slipping clutch could be caused by contamination of the new clutch itself.  if too much spline grease was used and then slung on the clutch after startup that could be the issue, as could a leak of the main seal.
just variables and food for thought while working through the issue.  First thing is to rule in or rule out clutch slippage after proper adjustment.
  • Caveman
« Reply #23 on: April 23, 2025, 03:11:53 PM »
I've followed the clymer manual and Chris harrels videos on adjustment using wire for a 3in measurement for the cable and proper play at the lever.
I'll document what I find inside once I get it open again. Haven't had much time lately to continue.
« Reply #24 on: April 23, 2025, 04:38:52 PM »
Now that you have asserted that the clutch linkage has been inspected and adjusted by the book, my Step 1 would be to pull out the driveshaft and check its u-joint for looseness or rough rotation before it breaks and the driveshaft possibly fractures the swing arm.
Rule out that the main engine ground terminal beneath the frame backbone is clean and also the wire terminals attached to it are also clean. Verify that the LE Jetronic's plug and its connections are clean and that it is tightly plugged in so that it cannot be loosened by pulling its plug in an outward arc to the left from where is cable is attached. Check the ignition control plug and contacts are clean and tight. Like Mighty Gryphon this could possibly be an electrical problem despite your description.
