Author Topic: 1995 K75 Rehab after 32K miles  (Read 84744 times)
Re: 1995 K75 Rehab after 32K miles
« Reply #50 on: April 30, 2025, 02:39:09 AM »
Posts #10 and #11 in this 2015 thread are relevant to your plans. I'm supplying the link in case you, or anyone else, hasn't read them. Pin #45 in the text actually refers to pin #15 on the relay and is likely a typo in the diagram.
Offline Cinderedblock
  • Caveman
« Reply #51 on: May 01, 2025, 06:09:09 PM »
I haven't started jumping things but I encountered a mystery switch behind the temperature  sensor with two wires and 3 positions. It doesn't force the fan on so I'm about to chase it.
  • Somewhere in the Carolinas, just follow the trail of oil.
1995 Silver K75 32,000 miles
1995 Red K75 18,000 miles -FS
2007 KLR-650 "Pipe Bomb"  -Previously wrecked and ready for round two
2023 BMW G310R - For getting to the auto parts store
  • Caveman
« Reply #52 on: May 01, 2025, 06:19:47 PM »
Mystery solved, that is an ignition switch bypass. It jumps out the key
« Reply #53 on: May 02, 2025, 08:32:55 AM »
Good catch! That could be contributing to engine's bucking problem.
  • Caveman
« Reply #54 on: May 02, 2025, 09:07:22 AM »
I probably should have listened to considering the engine, I found no issues in the cooling loop.
I'm going to replace the hall effect sensor. I understand they fail under heat and the forum post discussing it matches my description "Bucking Bronco". I also don't think anything I've tried so far would explain such a persisting intermittent issue.
* IMG_20250501_185258599_HDR.jpg (70.9 kB . 765x576 - viewed 3781 times)
Please link any helpful resources for installation. All I know is to mark it and make sure I install it identically.
On another note I have found more things
The seal on my gas cap is gone, new on order.
 Tank was 1/8 water, this probably happened due to me hosing the tank off several times these past few days. The fuel pump is "functional" but missing a mounting clip and I don't think it's OEM, the terminals for the power wires look different. There is a hose clamp involved too. Interesting
* IMG_20250501_202451895_HDR.jpg (57.62 kB . 765x576 - viewed 3978 times)
* IMG_20250501_202504868_HDR.jpg (55.55 kB . 765x576 - viewed 3797 times)
* IMG_20250501_205327252_HDR.jpg (38.65 kB . 765x576 - viewed 3943 times)
* IMG_20250501_205322979_HDR.jpg (36.7 kB . 765x576 - viewed 3839 times)
The power saver relay was super glued in it's socket. I cleaned the glue so it's a little loose but I'll put a ziptied on that like a professional.
* IMG_20250501_182809096_HDR.jpg (56.79 kB . 765x576 - viewed 3780 times)
* IMG_20250501_182752487_HDR.jpg (38.86 kB . 765x576 - viewed 3912 times)
There may be more electrical tomfoolery
« Reply #55 on: May 02, 2025, 01:39:05 PM »
That pump is a mess and could be part of the bucking problem because the fuel sock is partially clogged. Also, it probably doesn't have a low enough protrusion into fuel from its position in the holder. You can do better than that one without paying OEM price. The glue-spattered connector should be replaced if you can find one on ebay or in salvage.
I'm not convinced the Hall sensor is the problem because I'm uncertain this relic has been ridden long enough to get hot.  :laughing4-giggles: Have you done the static LED test on the sensor to determine if it's working at all?
  • Caveman
« Reply #56 on: May 02, 2025, 02:05:16 PM »
The fuel pumps access to gas would be easy to troubleshoot. But now that you mention it I can't say I've tested. If that's all it was Ill loose my mind. I never had problems when the tank got low enough for the fuel light to come on several occasions.
Can you help me identify the orange relay, I've got conflicting information, I seen it labeled fuel pump relay and power saver relay.
I pulled the fuel filter and the sock. The sock didn't have anything in it, just discolored in the picture. The fuel filter didn't have much problem forcing gas through it so I put it back for now. I didn't have a replacement on hand.  I should probably check the pressure, haven't inspected the regulator.
I have not tested the hall sensor and I dont dare try. I'm not convinced either but my symptoms feel similar. I looked at my ground connection at the transmission and it was incredibly corroded at the bolt so I  cleaned it up.
I'm just waiting to take it for a ride and gather more information when it fails next.
