Author Topic: 1990 K75 refresh  (Read 52948 times)
Offline Atabeach
1990 K75 refresh
« on: May 19, 2024, 09:21:17 AM »
Ok people...we have splines! Ergo, Project can continue. On that subject, I think I'm missing a ball bearing race. There is supposed to be one after the "puck" No?
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Re: 1990 K75 refresh
« Reply #1 on: May 19, 2024, 12:35:41 PM »
That is the revised clutch piston; there is no separate bearing. If the clutch was operating okay, the clutch rod is the appropriate one for this piston.
Offline Atabeach
« Reply #2 on: May 19, 2024, 01:29:12 PM »
Thanks Laitch!  That makes sense because the clutch measurement is 5.1. It’s new! Now about that gear indicator….Moving forward what’s a decent matching paint for the transmission case and swing arm?
  • Ponte Vedra Fl
Offline Atabeach
« Reply #3 on: June 01, 2024, 09:54:47 AM »
Ok Folks, we have decided to put the old clutch BACK in. The new clutch pack did not have balance marks of any kind. Question, the factory clutch installation ring / housing that came with bike did not have markings. But since I know the orientation, I put it back the same way. The motor and pressure plate have yelllow marks. The finger spring, and outer ring do not. Also the clutch seems to have a brass balance rivet. The new ( not installed ) clutch does not. The two yellow marks available are 120 degrees apart. Why wasn’t the outer ring marked?
  • Ponte Vedra Fl
« Reply #4 on: June 01, 2024, 11:06:05 AM »
I've never seen a clutch housing with that many holes in it! (They drill those to remove metal to get it balanced.)
Usually they have fewer holes.
« Reply #5 on: June 01, 2024, 11:21:23 AM »
You can check that off your bucket list! icon_cheers
If the clutch disc was within spec, what was the reasoning behind replacing the whole shebang, Atabeach—money laundering? Believe me; I know how it is down there, but real estate is the traditional method.
Offline Atabeach
« Reply #6 on: June 01, 2024, 11:55:51 AM »
The bike had 40k on it and came with an entire clutch assembly. I got cold feet installing the new one because it had no marks. Now I have a brand new assembly for any future K bikes I will probably add to my collection. Anybody have a left side swing arm bolt? I stripped the Allen portion.
  • Ponte Vedra Fl
« Reply #7 on: June 01, 2024, 11:59:16 AM »
It does make sense to put things back the way you found them but each part is individually balanced so it's not a huge deal. BMW also sells the parts individually, not as a balanced set. If it really mattered that much then they would not do that.
I once forgot to mark a clutch when disassembling and just reinstalled it. Worked fine.
Also the manual instructions are odd. It says offset by 120 degrees but not which way.
Offline Atabeach
« Reply #8 on: June 01, 2024, 12:02:02 PM »
Thank you so much because I’m getting nervous about the orientation.
  • Ponte Vedra Fl
« Reply #9 on: June 01, 2024, 01:13:47 PM »
That's not so odd. What matters to BMW—if not the rest of the world—is that the marks are separated from each other by the legs of the triangle they create instead of being stacked. The assembly is balanced regardless of which way it rotates or which mark is at either end of the triangle's base.
The obsessive among us might consider making one mark across the edges of the coupled assembly in one place before the assembly is removed, then reassemble the pack so the marks on their edges line up.
Failure in accurately aligning the clutch disc during assembly is what should really occupy obsession.  :laughing4-giggles:
Offline Atabeach
« Reply #10 on: June 01, 2024, 01:24:45 PM »
I did exactly that. I’m hoping it’s not THAT critical. The clutch itself should NEVER have marks? It rotates independently of the triangle…..being, the motor housing pressure plate and outer ring assembly. Am I missing something?
  • Ponte Vedra Fl
« Reply #11 on: June 01, 2024, 01:37:32 PM »
Lunch, perhaps? Listening to birdsong? You're getting there. Keep moving forward.
« Reply #12 on: June 01, 2024, 08:19:05 PM »
"Why wasn't the outer ring marked?"
There's a few possibilities. One possibility is that sometimes the mark is on the other side of the cover plate. Have a look for a paint mark on the other side, and it might not be visible until you remove it from the other balanced parts.
The diaphragm spring doesn't have a balance mark for the same reason you mentioned about the clutch, the balanced parts spin independently of them when the gears are changed.
Offline Atabeach
« Reply #13 on: June 01, 2024, 08:27:38 PM »
Not marked. Either side. Puzzling. Especially since this is definitely the original BMW install. I guess it may not matter that much….by the way, it never occurred to me the spring spins independently…ergo not balanced. Another puzzling thing the clutch DEFINITELY has a brass weight.
  • Ponte Vedra Fl
« Reply #14 on: June 01, 2024, 08:46:41 PM »
Photo, please.
« Reply #15 on: June 01, 2024, 08:48:42 PM »
The diaphragm spring spins with the clutch housing.
« Reply #16 on: June 01, 2024, 08:53:13 PM »
A couple of thought bubbles of how it seems to make sense to me. In the past I've replaced tyres. Removed the old one, removed the balance weights, installed the new one with the balance marks in the correct orientation, spun it up on a balancer, and it's balanced! Where do you put a balance weight if it's balanced first up? You don't! But then it looks like it's unbalanced cause there's no weights on it. Granted that's rare, but it sometimes happens.
The parts for balancing would be placed on a balancer, then a measured amount of steel would be removed, and then checked again for balance. If still out, more can be removed, but if only half a bees dick needs to be removed, re-drilling isn't required, simply a paint mark is placed on the heavy spot. But what if it's perfectly balanced when checked again, where would you place a balance mark? You wouldn't! This would happen more often than we might think because a calculated amount of steel is removed for initial balancing. It's a safe bet that BMW would put these parts aside, so if you buy a clutch pack, the balanced parts would all have a balance mark, or none would. I think it's a safe bet that your clutch pack parts are balanced and can be installed regardless of orientation. If there are balance marks, the three marks should be spaced evenly apart at 120 degrees.
Puzzling.
The cover plate may have been replaced with a balanced, unmarked one. It may have been oil soaked and cleaned by a previous owner who did a Mickey mouse job, removing the mark. Some riders aren't aware there are balance marks from the factory, especially since the repair manual says to mark the parts, and they could be black all over. Sometimes it's a thick blob and chips off with a rough handling.
True enough my description of the diaphragm spring is crappy, maybe I should have said it doesn't have to be synchronised with the balanced parts, which are not symmetrical, or something like that.
Offline Atabeach
« Reply #17 on: June 01, 2024, 10:13:26 PM »
Two photos for Laitch, showing brass weight/rivet… please note my wife’s nail polish used for torque marks
  • Ponte Vedra Fl
« Reply #18 on: June 01, 2024, 10:23:20 PM »
Actually it does say. For example the Clymer manual says either clockwise or counterclockwise, because it just doesn't matter.
Have you had it going, I'm wondering if there is a vibration which might be why a clutch pack was ordered.
Offline Atabeach
« Reply #19 on: June 01, 2024, 10:52:13 PM »
The bike was running no vibrations whatsoever. Took her apart to lube and inspect clutch wear. The bike will get refresh paint, light relays and basic upgrades. I’ll post as I go. Thanks for the input.
  • Ponte Vedra Fl
Offline Atabeach
« Reply #20 on: June 01, 2024, 11:00:18 PM »
Laitch, to be clear…the first phot shows the orientation when I took boot off. Did YOUR photo suggest otherwise. The cup portion of disk should go toward the front of bike..right?
  • Ponte Vedra Fl
« Reply #21 on: June 02, 2024, 01:22:35 AM »
Get ready for multiple incoming longshots here. Does the yellow mark on the clutch basket look more like a paint stain where a yellow paint blob used to be? Yes, I think it does.  Looking at a small phone screen here, so not sure. Let's say the paint marks have been scrubbed off. Ok if we look at the cover plate above this spot, or 120 degrees from it, do we see a yellow stain? Yes, I think we do.
In the first photo of reply 17 at about nine o'clock (third bay below the 070 mark) I think I see a yellow stain, maybe you can confirm this, I'm not sure. Anyway this is either above the clutch basket yellow mark or 120 degrees from it. I'll hazard a guess that this is 120 degrees from both the yellow mark on the clutch basket, and also 120 degrees from the yellow mark on the pressure plate.
Bit of a long shot? Yes, but then it's a bit of a coincidence if it's 120 degrees from the clutch basket mark.
« Reply #22 on: June 02, 2024, 06:44:32 AM »
My photo suggested otherwise. There is no disk. There is a piston. Here's how it works. The clutch arm bolt should contact the solid surface in the center of the piston, not the hole. The spring should sit in the recess of the piston to help stabilize it within the boot. The clutch rod enters the hole on the opposite side of the piston to stabilize it under pressure.
Either you didn't notice how it was assembled when you disassembled it or it was assembled incorrectly. If it was assembled incorrectly, it may not have worked smoothly sometimes.
I now realize that two pictures weren't worth a thousand words, and six words weren't worth anything either.
 :laughing4-giggles:
Thanks for the clutch disk photo. That rivet has a certain je nais se qua. It probably has a purpose, like a nose ring; too bad it's hidden from public view. I prefer the garden-variety spoked clutch disk without mysterious, stylish accoutrements.
« Reply #23 on: June 02, 2024, 09:50:53 AM »
I spose since the clutch is made up from multiple parts it's not surprising that it might not always be well balanced and might need a balance weight in some cases.
Offline Atabeach
« Reply #24 on: June 02, 2024, 10:07:21 AM »
Laitch, Thanks for the clarity on the boot. I'm certain of a couple of things here.1)  The boot disassembly was EXACTLY in photo.2) The boot was replaced at some point because it its new and there is a pry knurl on the clamp. 3) The transmission was NEVER separated from motor...the clutch & splines not seeing the light of day since manufacture. The irony here is everything was working flawlessly. To coin a phrase " IF IT AINT BROKE FIX IT TILL IT IS" ...pure genius! Thanks Laitch. As a side note;  the schematic parts drawing looks like the cup side goes toward motor, not toward spring.
  • Ponte Vedra Fl
