Author Topic: Oil Pressure Switch Wires  (Read 2727 times)
Offline RetroTexan
« on: June 25, 2023, 10:22:14 AM »
1989 K100LT
I have 2 wires coming from the Hall Sensor Cover that disappear into the engine towards the oil pressure switch.
One is a black OEM wire (the tag is ripped so I can’t see the oem label) and the other is a green/brown that I understand goes to the oil pressure sensor.
Does anyone know what the black wire is supposed to be?
  • San Marcos, TX
  • 1990 K100 Custom Scrambler
Re: Oil Pressure Switch Wires
« Reply #1 on: June 25, 2023, 11:13:59 AM »
Sensor for the temp gauge.
Offline RetroTexan
« Reply #2 on: June 25, 2023, 11:57:35 AM »
Mmm I'm not sure that's it. Unless I’m mistaken, the wires for the Temp Sensor are Green/Violet and the sensor itself is attached to the engine in a different location just below the fan (pic attached)
  • San Marcos, TX
« Reply #3 on: June 25, 2023, 12:17:17 PM »
The temperature gauge is the topic of frankenduck's post. If you've got a gauge, there's a temperature sensor screwed into the water pump to which the gauge is attached by the wire illustrated here.
Offline RetroTexan
« Reply #4 on: June 25, 2023, 12:19:30 PM »
Disregard my last comment, y'all are both correct. Looks like it is for a second sensor for a Temp "Gauge" which is connected to Additional Instruments. My wiring diagram doesn't show it which had been confusing me.
https://www.k100-forum.com/t10611-sensor-electric-contact-cleaning-maintenance
Thanks for the reply!
  • San Marcos, TX
