Author Topic: trip meter adjustment knob 86 75C  (Read 3181 times)
Offline jad01
« on: May 29, 2023, 01:38:27 PM »
Well, this is not a new problem, but has been low priority.  When I bought my K75C, the trip meter was non-functional, but the PO had a new one, complete with the adjuster knob ("button") in the kit.  So, several years ago I endeavored to change it while replacing some non-functional bulbs.  I fitted the new odometer and bulbs, buttoned everything up, and all was good.  Until... the adjuster knob apparently fell out on the road somewhere.  177381
I had the old knob, and have since been keeping it in the under-seat tray, and just adjust the trip meter when needed (usually to track fuel mileage). But, this leaves an open hole on the side of the instrument cluster.  Plus, I'd like to have the knob affixed where it belongs.
My question: how does the knob stay "put" on the cluster?  I looked at the parts diagram on Duck's site, and it looks like it may just be retained by an o-ring?  My adjuster knob (the original one) is only the plastic knob with a notch at the end (I see the diagrams and some pics show a spring, e-clip, etc.  think
Jim
'86 K75C, '84 R100RS, '78 R80/7
Re: trip meter adjustment knob 86 75C
« Reply #1 on: May 29, 2023, 02:04:09 PM »
My question: how does the knob stay "put" on the cluster? .  . . I see the diagrams and some pics show a spring, e-clip, etc.
Those diagrams are your guide, like the ones found in this post.
« Reply #2 on: May 29, 2023, 02:13:02 PM »
There's two generations of the trip odo knob, one with a plastic shaft(old) and one with an aluminum shaft. As an 86 yours most likely came with the old one.
I don't have a picture of a complete old one but here's a partial one.
And here's a diagram of it:
The problem with those was, as you've found out, that when the E-clip at the end pops off the spring no longer holds the knob in. It may be possible to fix it if you take the cluster apart and find the missing parts floating around loose inside of the cluster.
The newer one looks like this and doesn't come apart like the old one does:
Yes, the newer, better one will replace the old one.
Offline jad01
« Reply #3 on: May 29, 2023, 05:18:25 PM »
Ah! OK, this makes sense now-thanks.  That's the one I have.  I'll see if I can locate a newer one to make the repair.
* IMG_20230529_152948981.jpg (37.46 kB . 768x576 - viewed 363 times)
Jim
« Reply #4 on: May 29, 2023, 06:04:35 PM »
Look inside the cluster first. You can probably repair yours. Just don't pull it out very hard or at all as there's really no need to do anything other than turn it.
Offline jad01
« Reply #5 on: May 29, 2023, 09:04:29 PM »
Let me see if I can find that stuff.  If it's not in the instrument cluster, I might well have it in a bag in my spares with the old (non-functional) trip meter from when I changed it out.  Now that you told me how it's supposed to work and shared that pic, I suppose I could find a clip and light spring at ACE if it came down to it.
Jim
« Reply #6 on: May 29, 2023, 09:40:31 PM »
Or Tacoma Screw in Portland. They have EVERYTHING.
Offline jad01
« Reply #7 on: June 11, 2023, 12:34:49 PM »
Progress report: I found the spring in my stash! icon_cheers  No clip though... thanks for the tip on Tacoma Screw, I may have to make a run there.
Jim
« Reply #8 on: June 11, 2023, 01:24:21 PM »
They've got four pages to choose from—exciting stuff!  icon_cheers
Offline jad01
« Reply #9 on: June 11, 2023, 01:31:15 PM »
It's the little things in life...  :laughing1:
Jim
