Hello everyone
I finally feel pressured to write my first post, as i have hit an issue that i for the first time cannot solve myself with the guidance of my Clymer manual and the posts on this forum. I humbly seek your guidance.
The bike:
K1100LT
The problem:
Streaks of yellow appearing in my sight glass on my last few rides in October before winter storage (Denmark it is 3 months, december-april), i decided to now drain the oil, and have a look at where the water could be coming from. As you can see in the attached picture, the water amount isn't crazy (there is picture of first drain and second drain where it drained for 2 days), but it has me worrying if i have an internal coolant leak/crack.
IMG20230301185429.jpg (53.25 kB . 432x576 - viewed 720 times)Could this just be condensation from the last few trips? (They weren't long) or being stored for 3 months? Or am I looking at a serious problem?
What i have already done;
Complete rebuild (not head or pistons), all gaskets, seals, o-rings, water pump, you name it, i have changed it, last winter 2022.
Compression test 140-138-139-140, so no cylinder leaks
Weep hole check, no blockage as i made sure to do it properly when rebuilding pump and checked just now.
Coolant system pressure test @16 psi for 6 seconds and 15psi for 1h +, no apparent loss of pressure, and no leaking coolant when I view the block from below with oil pan removed.
IMG20230301181833.jpg (46.28 kB . 432x576 - viewed 711 times)I am stumped as to what to do next, am i being overly worried about condensation? Any tips or opinions will be appreciated dearly.
Sincerely Kalen
