Author Topic: Coil might be bad  (Read 9680 times)
Offline FlatSix
Coil might be bad
« on: May 31, 2022, 08:26:34 PM »
Gents,
Went for a ride with the wife (a month ago before it got blazing hot) and it was barely running.  Quick turnaround (wife not pleased) and parked the brick.  Last ride before that it started fine but seemed to be running rough by the time I got home.  I suppose it didn't magically fix itself.
Removed the plastics to get a good look at things to see what's up.  You know...just the usual, hey maybe something fell off or something.  No obvious missing parts.  Bummer.  Perhaps an air leak (I visually checked but didn't get around to testing with propane) but nearly every rubber part is newish.  Pulled the plugs and they looked good.  Got out the multi-meter to make sure the coils were giving me the juice and got some unexpected readings so I pulled them off the bike to make sure I tested them properly.
Looks like one for sure and possibly both might be bad.  Is 10.72 ohms serviceable for 2 - 3 coil or is it bad too?  It's not easy to get readings on the high voltage side but I happen to have some long probes  :laughing1: and I assure you they were making contact....I promise!
And what kind of junk coil fails after only 35 years? :idunno:
Dave in TX
  • TX
  • K100LT
Dave in TX
1987 K100LT project
1971 Triumph Bonneville -sold to a couple young female tattoo artists
Re: Coil might be bad
« Reply #1 on: May 31, 2022, 09:02:20 PM »
Is 10.72 ohms serviceable for 2 - 3 coil or is it bad too? :
10.72Ω or 10.72kΩ?
« Reply #2 on: May 31, 2022, 09:21:19 PM »
Looks like you have first gen coils.  I'd replace both of them with a good pair of used second gen coils.
« Reply #3 on: May 31, 2022, 09:38:57 PM »
+1  The early coils had a problem with insulation breakdown.  Used 2nd generation coils are almost bulletproof.
« Reply #4 on: May 31, 2022, 09:57:01 PM »
If you're looking on Ebay or wherever for coils then it's easy to tell first gen K100 coils from second gen coils. The spark plug lead terminals are orange instead of dark gray.
Offline FlatSix
« Reply #5 on: May 31, 2022, 10:06:54 PM »
10.72Ω or 10.72kΩ?
Haha!  It's the "K" version of course...my bad.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
Offline FlatSix
« Reply #6 on: May 31, 2022, 10:10:41 PM »
Duly noted sirs.  Thanks for the help.  I will be on the lookout for a set of newer second gen ones.  The "new" ones at Max are pretty pricey and not sure if they can even be had.  Yikes.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #7 on: May 31, 2022, 10:52:43 PM »
For the record, here is an extract from the compelling literary work, BMW Diagnose–Testing for K Models, which tells us that one of the coils is OK— until it isn't, which essentially is a description of the general condition of humanity, too.  :laughing4-giggles:
Offline FlatSix
« Reply #8 on: June 01, 2022, 09:44:47 AM »
Thanks Laitch that is very helpful.  The "Troubleshooting Guide" I have saved on my computer just shows the High Voltage segment of the coil should test about 12.6K ohms.  I should be able to get on the road quicker if need be with only one coil.
I do think I am going to try and get two newer version good ones if I can find them.  My objective in rebuilding this bike was to make it as reliable as possible by replacing or upgrading any potential wear items.  The coils were one of those items that I should have just bought new when I put it together.  $$$  You live, you learn.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
Offline FlatSix
« Reply #9 on: June 01, 2022, 11:53:54 AM »
Follow up:  Can the coil, part number 12131459890 be used, if the wiring can be adapted?  Looks like it uses a different plug.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #10 on: June 01, 2022, 12:13:48 PM »
That coil is from the K1100 and works with the Motronic system.  Your bike has the Jetronic, and the ignition signals may not be the same.  I would go with a K100 coil to be sure it will work and not damage anything.
https://www.ebay.com/itm/123719811660?fits=Make%3ABMW&hash=item1cce46824c%3Ag%3AITgAAOSwtfhYrLkM&LH_ItemCondition=4
Offline FlatSix
« Reply #11 on: June 01, 2022, 02:22:29 PM »
Thanks TMG, I will stay with what I know works.  The link you sent...that coil has a different plug than mine as well.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
Offline beemuker
« Reply #12 on: June 01, 2022, 02:58:33 PM »
List says compatible with K100RS, not 100LT. only 1100lt. keep looking. I just got one for $50 for my R1100.
  • Panama City, FL
« Reply #13 on: June 01, 2022, 03:27:43 PM »
The list is referring to the 4V version of the RS, not the 2V.
« Reply #14 on: June 01, 2022, 03:35:13 PM »
Doh!  The coil I linked is for the Motronic system.  Don't use it.  I don't know what I was thinking when I looked at the listing.
Offline FlatSix
« Reply #15 on: June 01, 2022, 03:53:36 PM »
Thanks guys.  I am on the hunt.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
Offline Duckbubbles
« Reply #16 on: June 02, 2022, 06:46:59 AM »
I am using the stock coils on my '85 K100RS with a '93 K1100LT Motronic.  Had to modify the ignition leads to plug into the earlier coils.  I believe the difference between early and late coils is the way the trigger leads attach.  The early coils use separate blade connectors while the later coils use a two pin plug.
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'23 R1250RS
'03 R1100S BCR #6/200
500,000+ BMW miles
« Reply #17 on: June 02, 2022, 07:54:14 AM »
I believe the difference between early and late coils is the way the trigger leads attach. .  .
Another difference is that K1100 4V coils have 0.5Ω primary resistance and ≈13.5kΩ secondary resistance, compared with ≈2.5Ω primary resistance and ≈10.5kΩ secondary resistance in the 2V coils. What you've done is used coils in your K1002V appropriate for use with the Motronic in your 2V. Using them with a Jetronic ECU might have a different result, as indicated by this observation.
I'd be careful about using coils with a lower primary resistance.  This will cause more current to be drawn through the ICU drivers, and possibly destroy the ICU (as the drivers will overheat).
Offline Duckbubbles
« Reply #18 on: June 02, 2022, 12:32:41 PM »
I did no research on the differences in the coils.  I've been using my original '85 coils on my '85 RS while running a '93 K1100LT engine, Motronic, airbox, engine harness, O2 sensor and adapted the '85 bike wiring harness to run the Motronic..  The conversion was done (by me) 19 years and 50,000 miles ago.
Picked up the engine and systems from a salvage yard and probably should have gotten the coils, too.  Wouldn't have had to replace the coil trigger plugs.
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'23 R1250RS
500,000+ BMW miles
Offline FlatSix
« Reply #19 on: June 02, 2022, 02:18:26 PM »
Frank
It is good to hear you haven't had any issues with this setup, fellow Texan.
In looking for the newer versions of the coil I need I received disheartening news when inquiring about new ones:  "Unfortunately these coils are discontinued by BOSCH and BMW with no aftermarket option available.  We have sold the last of our inventory and will not be able to replace them."
I have not yet exhausted my search.
There must be someone smart with this electrical wizardly that can figure out how to use an alternative coil.
Dave
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #20 on: June 02, 2022, 02:59:24 PM »
Just for laughs, you might want to place an order for p/n  12 13 1 459 513 from MaxBMW.  Their website doesn't show it as not available so maybe there are still some around.
It's going to be a bit pricey at $242, but there is no shipping or sales tax.
Offline FlatSix
« Reply #21 on: June 02, 2022, 03:02:24 PM »
I'm ahead you there TMG...waiting to hear back and hoping for good news.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
Offline FlatSix
« Reply #22 on: June 03, 2022, 11:19:13 AM »
No joy.  I will post in the WTB section to see if there are any out there.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #23 on: June 03, 2022, 12:22:33 PM »
No joy.
Does that mean Max didn't respond to you, they responded that none are available, they responded that there was a long waiting period before you'd get one, or that you're just despondent in general?
Offline Duckbubbles
« Reply #24 on: June 03, 2022, 12:42:26 PM »
There used to be two motorcycle salvage yards within 100 miles of me- both are long gone.
The last gasp option might be adapting coils from another brand of four cylinder motorcycle.  Perhaps even four separate car coils if they are small enough.
Adapting your spark plug leads is a different story.  Long years ago I tried a set of Luftmeister spark plug leads that were built like automotive style but they had a intermittent misfire so I reinstalled the stockers.
Good luck!
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'23 R1250RS
500,000+ BMW miles
