Ignition switched tap: where ?
Topic: Ignition switched tap: where ? (Read 3030 times)
alexg
^ Proficient Motobricker
May 04, 2022, 05:21:17 PM »
Hi all:
I bought a hyper-light brake light kit and it requires a hot with ignition power source. Any recommendations where is more convenient?
Michigan
'93 K75S, 1975 BMW R75/6 & 1984 Yamaha RZ350
Alex G.
frankenduck
Adrninistrator
Re: Ignition switched tap: where ?
Reply #1 on:
May 04, 2022, 05:35:21 PM »
Green/black wire of the connector for the rear brake switch. (Under right side cover.)
Or white nylon connector in the relay box - green/brown wire.
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
alexg
Reply #2 on:
May 04, 2022, 07:00:11 PM »
That works. My bike has ABS, can I tap from the computer? Shorter run to the rear light. Thanks !
Michigan
Alex G.
frankenduck
Adrninistrator
Reply #3 on:
May 04, 2022, 07:06:22 PM »
If you want to tap near the rear then tail light power - gray/black.
New to K bikes?
Click here.
Click here.
alexg
Reply #4 on:
May 04, 2022, 08:30:08 PM »
Of course, rear position light is always on! Thanks !!!
Michigan
Alex G.
alexg
Reply #5 on:
May 05, 2022, 07:46:41 PM »
Installed the two 8-LED modules to the side of the regular brake light. Looks like it was designed that way. I am very happy. Tapped all the needed connections at the rear light as well. Thanks for the suggestions.
Michigan
Alex G.
Past-my-Prime
^ SuperNatural Motobricker
All of us are better when we're loved.
Reply #6 on:
May 08, 2022, 03:59:49 PM »
Photos? And where did you source your lights?
North Shore of Lake Superior (in my garage)
BRICK: 1989 K75 RT - Rocinante; NON-BRICK: 2007 F650 GS Dakar - Betty Blue
alexg
Reply #7 on:
May 11, 2022, 01:09:07 PM »
Photo as requested. It is annoying to look at! Bought it from Sierra BMW in Reno, Nv.
Michigan
Alex G.
foliver
Reply #8 on:
May 11, 2022, 10:29:07 PM »
Hi Alex, very nice!
this ones?
https://hyperlites.com/?product=u32-kit
Montevideo, Uruguay
Bmw K75C 86
alexg
Reply #9 on:
May 11, 2022, 10:58:04 PM »
That brand, but the ones with only 8 LEDs per side. I cannot confirm that the 16 LEDs will fit in the space.
Michigan
Alex G.
foliver
Reply #10 on:
May 11, 2022, 11:01:29 PM »
Do you have a link?
Montevideo, Uruguay
Bmw K75C 86
alexg
Reply #11 on:
May 11, 2022, 11:11:52 PM »
https://hyperlites.com/?product=universal-kit
It is in the same site, just a few clicks away. Cheaper too.
Michigan
Alex G.
foliver
Reply #12 on:
May 12, 2022, 05:14:27 AM »
Txs Alex!
good find
Montevideo, Uruguay
Bmw K75C 86
