Author Topic: Ignition switched tap: where ?  (Read 3029 times)
Offline alexg
« on: May 04, 2022, 05:21:17 PM »
Hi all:
I bought a hyper-light brake light kit and it requires a hot with ignition power source. Any recommendations where is more convenient?
Thanks
  • Michigan
Alex G.
Re: Ignition switched tap: where ?
« Reply #1 on: May 04, 2022, 05:35:21 PM »
Green/black wire of the connector for the rear brake switch. (Under right side cover.)
Or white nylon connector in the relay box - green/brown wire.
Offline alexg
« Reply #2 on: May 04, 2022, 07:00:11 PM »
That works. My bike has ABS, can I tap from the computer? Shorter run to the rear light. Thanks !
  • Michigan
Alex G.
« Reply #3 on: May 04, 2022, 07:06:22 PM »
If you want to tap near the rear then tail light power - gray/black.
Offline alexg
« Reply #4 on: May 04, 2022, 08:30:08 PM »
Of course, rear position light is always on! Thanks !!!
  • Michigan
Alex G.
Offline alexg
« Reply #5 on: May 05, 2022, 07:46:41 PM »
Installed the two 8-LED modules to the side of the regular brake light. Looks like it was designed that way. I am very happy. Tapped all the needed connections at the rear light as well. Thanks for the suggestions.
  • Michigan
Alex G.
Offline Past-my-Prime
« Reply #6 on: May 08, 2022, 03:59:49 PM »
Photos? And where did you source your lights?
Offline alexg
« Reply #7 on: May 11, 2022, 01:09:07 PM »
Photo as requested. It is annoying to look at!  Bought it from Sierra BMW in Reno, Nv.
  • Michigan
Alex G.
Offline foliver
« Reply #8 on: May 11, 2022, 10:29:07 PM »
Hi Alex, very nice!
this ones?
https://hyperlites.com/?product=u32-kit
  • Montevideo, Uruguay
  • Bmw K75C 86
Offline alexg
« Reply #9 on: May 11, 2022, 10:58:04 PM »
That brand, but the ones with only 8 LEDs per side. I cannot confirm that the 16 LEDs will fit in the space.
  • Michigan
Alex G.
Offline foliver
« Reply #10 on: May 11, 2022, 11:01:29 PM »
Do you have a link?
  • Bmw K75C 86
Offline alexg
« Reply #11 on: May 11, 2022, 11:11:52 PM »
https://hyperlites.com/?product=universal-kit
It is in the same site, just a few clicks away. Cheaper too.
  • Michigan
Alex G.
Offline foliver
« Reply #12 on: May 12, 2022, 05:14:27 AM »
Txs Alex!
good find
  • Bmw K75C 86
