Author Topic: Gauges - Gas and water temperature  (Read 5140 times)
Offline AtLarge
  • Not too many bikes. Garage too small.
« on: April 24, 2022, 09:29:50 PM »
Are the OEM supposed to have a backlight?  Mine are not obviously.   :laughing1:  They work but, are pretty rough looking so, I am thinking about replacement.  Also, I searched the site and do not see where anyone has replaced the original units with aftermarket digital.  Anyone tried it and / or suggestions?  TIA.
  • IA
  • 1994 K1100RS
1973 Honda CL70-K3, 1975 Kawasaki 350 F9-C, 1994 BMW K1100RS, 2023 Honda CRF300L Rally ABS
Re: Gauges - Gas and water temperature
« Reply #1 on: April 24, 2022, 10:21:10 PM »
I run these in all of my Ks:
« Reply #2 on: April 24, 2022, 11:22:44 PM »
I . . . do not see where anyone has replaced the original units with aftermarket digital.
That's likely because the BMW fuel level sender is not compatible with modern digital gauges without some modification. rbm explains the modification in the later part of this thread . The matched VDO set seems like the way to go.
« Reply #3 on: April 24, 2022, 11:34:54 PM »
Yeah, the BMW fuel lever sender is "backwards" compared to most. (Low ohms when full, high ohms when empty.) The VDO above is also "backwards" so it is plug-n-play on K bikes.
I've looked for 2" digital ohmmeters but never found one. (When you get near 110 ohms you know you're running on fumes.)
Offline AtLarge
« Reply #4 on: April 25, 2022, 07:55:27 AM »
 112350 Thanks Guys. This helps a lot.
  • IA
  • 1994 K1100RS
« Reply #5 on: April 25, 2022, 12:51:54 PM »
I can't say about the temperature, but I checked a few sites and it appears VDO has discontinued the fuel gauge.  There was one place that didn't mention not having any.
These guys were the only ones who didn't say the gauge was not in stock.  Judging from the price it might be an old listing.
https://vehiclecontrols.com/shopping/shop700/products1/948-301-107-vdo-vision-black-fuel-gauge-for-tube-type-sender-90-0-ohm/#.YmbRMNPMLVI
It seems the Vision series has been discontinued.  I did see one that had a similar resistance characteristic with a different VDO part number.  Here it is:
https://www.etbinstruments.com/index.php?route=product/product&product_id=194
« Reply #6 on: April 25, 2022, 01:51:33 PM »
Summit says "Ship today" on the fuel gauge
https://www.summitracing.com/parts/vdo-301107?seid=srese1
Offline AtLarge
« Reply #7 on: April 26, 2022, 10:02:08 AM »
Unfortunately, it's really my temperature gauge that is the worse for wear.
It does still work and appears to be fairly accurate but, the lens is getting to the point of almost unreadable.
Anyone know if there anything special about that one or will any aftermarket 2 1/16'' digital water temperature gauge work?
  • IA
  • 1994 K1100RS
Offline AtLarge
« Reply #8 on: April 26, 2022, 10:17:42 AM »
Ok, found this so, not without changing the sender too.   177381
https://www.k100-forum.com/t9487-coolant-temp-gauge
  • IA
  • 1994 K1100RS
« Reply #9 on: April 26, 2022, 01:24:53 PM »
If you watch eBay, you will see that OEM gauges do come up fairly regularly although they do seem to be getting a bit pricey these days.
« Reply #10 on: April 26, 2022, 02:35:51 PM »
Looks like backwards could be the way to go despite its cost, AtLarge, if you're after that certain je nais se quois:laughing4-giggles:
« Reply #11 on: April 26, 2022, 04:00:19 PM »
Max BMW shows the prior part number gauges available for $75.20 and $82.25.
https://shop.maxbmw.com/fiche/PartsSearch.aspx?&searchtype=undefined&parts=62131459255%0A62131459256
Offline foliver
« Reply #12 on: April 26, 2022, 04:36:45 PM »
I would like to see a way to mount them in a K75C, I mean with the little fairing.
Someone has an idea how to mount them in an “elegant?” way?…..
The 7liters light makes me nervous….jajaj
  • Montevideo, Uruguay
  • Bmw K75C 86
« Reply #13 on: April 26, 2022, 07:22:50 PM »
Possibly a not too good seal. Cleaning the inside of the glass might be a big help.
« Reply #14 on: April 26, 2022, 08:05:11 PM »
Won't help. The lenses on the factory gauges delaminate over time.
Offline foliver
« Reply #15 on: April 26, 2022, 10:24:40 PM »
you cannot replace the lens?, glass?
  • Bmw K75C 86
« Reply #16 on: April 26, 2022, 11:18:32 PM »
It might be better to disable the 7 litre light. Some gauges are enclosed and mounted separately. The trip meter is another good way to track your fuel.
« Reply #17 on: April 29, 2022, 12:04:49 PM »
« Reply #18 on: April 29, 2022, 05:05:37 PM »
Hesitate thou not, AtLarge, unless thou hast foresworn and moved on.  Pray
« Reply #19 on: April 30, 2022, 06:18:43 AM »
I wrote up a DIY posting on the other K-bike forum on how to make a gauge housing from readily available PVC piping.  Once you get it into a housing, you can mount the housing anywhere convenient.
https://www.k100-forum.com/t1400-build-a-diy-single-instrument-cup
Offline triplek
« Reply #20 on: May 09, 2022, 01:50:42 PM »
You can replace the lens. The delamination everyone sees is from a flexible piece of rubber like material that is on the inside of the plastic.
To replace the lens - very carefully and with a fine pick remove the metal cover holding the lens to the instrument face.
Work the pick with small prys to gently and evenly bend the metal away.  Go around in a circle many, many times until it just gives space to pop off the cover.
Replace lens and reseal. And although I haven't tried it yet, I'd consider looking for a thin O ring to help restore the seal when replaced. Either way, I haven't had a problem with the less than the factory seal when re-lensed.
"Every time you criticize my grammar, I like you a little bit fewer."
1995 K75 RTP, 1995 K75 RT, 1993 K75, two K75 frames, 1 fully assembled engine from airbox to exhaust tip and enough fairings and  parts to build another K. Soon.  ;)
