You can replace the lens. The delamination everyone sees is from a flexible piece of rubber like material that is on the inside of the plastic.
To replace the lens - very carefully and with a fine pick remove the metal cover holding the lens to the instrument face.
Work the pick with small prys to gently and evenly bend the metal away. Go around in a circle many, many times until it just gives space to pop off the cover.
Replace lens and reseal. And although I haven't tried it yet, I'd consider looking for a thin O ring to help restore the seal when replaced. Either way, I haven't had a problem with the less than the factory seal when re-lensed.
