Deoxit D5 as preventive maintenance?
Topic: Deoxit D5 as preventive maintenance? (Read 2502 times)
foliver
^ Proficient Motobricker
February 05, 2022, 07:20:18 AM »
Hi!
i would like to know your opinion on the Deoxit D5 as preventive maintenance.
I'm slowly reassembly my bike, and i don't know if it's good to apply to every connection the next procedure:
1.Compressed air
2.Deoxit 5
3. 4 or 5 actuations ( plug unplug)
4. Compressed air to liberate the excess
Or i just need to do that to the ones that "i've doubt in the proper electrical transmission"...
Montevideo, Uruguay
Bmw K75C 86
Laitch
Faster than a speeding pullet
Administrator
Re: Deoxit D5 as preventive maintenance?
Reply #1 on:
February 05, 2022, 08:54:26 AM »
You can do n
o
2 only and have good results or compressed air and n
o
2 or connect and disconnect once with n
o
2. Just don't forget the n
o
2.
Along the Ridley in Vermont.
1995 K75 102,000 miles
Agree x 1
View List
The Mighty Gryphon
Administrator
Reply #2 on:
February 05, 2022, 10:10:25 AM »
I usually do #2 and #3. No need for air. When the Deoxit "dries" it leaves a very thin film that will protect the connection.
On the lugs that make ground connections on the frame and transmission I will polish them with very fine sandpaper or a wire brush and wipe them with a very light coat of grease on a rag to slow down corrosion. You should not be able to see the grease on the lug and barely feel it. That is all it takes to protect the connection.
In my garage in Marilla, NY
'91K100RS White/Blue
foliver
Reply #3 on:
February 05, 2022, 11:31:28 AM »
I will not forget the number 2, promise, jajajajja, i'll follow the earth procedure!!
Thanks for your time, Mighty and Laitch
Montevideo, Uruguay
Bmw K75C 86
