Author Topic: front weel bearings K75  (Read 4392 times)
Offline foliver
« on: July 04, 2021, 07:20:26 AM »
Helo all!
I'm working on my K75 to wake it up after 6 years, and i would like to know how to test if my front bearings are good, or if i change them straight.
i'seen these:
https://www.euromotoelectrics.com/product-p/wheelbearing335.htm
i guess is a 2 bearings and 2 bearing seals for the front wheel right?
Thanks!
  • Montevideo, Uruguay
  • Bmw K75C 86
Re: front weel bearings K75
« Reply #1 on: July 04, 2021, 08:59:22 AM »
i guess . .  .
You aren't actually guessing, are you, foliver? You have a service manual, correct?
Those bearings are not for your moto's front wheel. Look at the Application Table on that page. Your moto isn't on its list for fit. That bearing is an angular ball bearing. Yours are sealed grooved ball bearings.
Test the bearings in the wheel when it is mounted on the fork. With the wheel off the pavement, grip the wheel on opposite sides then try to wiggle it backwards and forwards. Move the wheel 90º and try wiggling it again. If there is no movement, rotate it to listen for grinding within the bearing. Don't mistake the noise of brake pads scraping on the rotor for noise coming from the bearings. Listen at both sides of the wheel.
If there is no movement or noise, replacement of the bearings is your choice and depends on your ability to tolerate uncertainty.  :laughing4-giggles:
Offline foliver
« Reply #2 on: July 04, 2021, 11:16:11 PM »
Hello Laitch, thanks for your repply.
You are right!, i've found the correct ones:
https://www.euromotoelectrics.com/product-p/wheelbearing967.htm
Yes, i've the manual!
i think even if they feels ok, i'll change them, i've spend so much money on parts, that it worth the pain, thinking in a long trip, i want to concrete for the next year.....
thanks again for the tips.
fabian
  • Bmw K75C 86
Offline volador
  • NEEDS MORE CHROME
« Reply #3 on: July 04, 2021, 11:59:44 PM »
Welcome
Some links for your K journey
Just bought a 2V
Just bought a 4V
Check parts compatibility with BMW MAX Microfiche, BOBS BMW, REAL OEM
https://shop.maxbmw.com/fiche/PartsFiche.aspx
https://shop.maxbmw.com/fiche/PartsSearch.aspx
https://parts.maxbmw.com/BMW___BmwMotorradK.html
https://www.bobsbmw.com/store/microfiche/BrowseSeries.aspx
https://www.realoem.com/bmw/select.do?kind=M&arch=1
https://www.ascycles.com/BMW-Motorcycle-Parts-Fiche
Cross reference parts like Bosch pn#'s, etc....  http://partsplusecat.com/
No spaces in the part number
Parts Vendors
https://www.beemerboneyard.com/
https://www.capitalcycle.com/
https://www.tills.de/
Headlight relay stuff if you chose to add one
https://www.motobrick.com/index.php?topic=268.0
http://www.motobrick.com/index.php/topic,4962.msg30932.html
http://culayer.com/product/matchbox-headlight-relay/
http://easternbeaver.com/Main/Wiring_Kits/H4_Kits/h4_kits.html  Eastern Beaver site is a great reference for electrical connectors,plugs, etc...
http://www.k100-forum.com/
http://www.kforum-tech.com/Tech-page.html
http://www.kforum-tech.com/electrical/EFI/bike-wont-start-EN.htm
http://www.kforum-tech.com/Downloads/electrical/diagrams/interactive_diagrams.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k100tshoot/K100.Troubleshoot.Start.2018.pdf
http://kbikeparts.com/index.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/ckb.new2k.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/ckb.tech.toc.htm
http://www.eilenberger.net/K75S/IgnitionSwitch/
http://www.verrill.com/moto/moto.shtml
this site has a lot of good info and breakdown pictures in the tech and tech resources sections for K1100 alot of the parts are on K75 & K100
http://www.k11og.org/forum/index.php?sid=2df953dde5715fd9001fbe69edec5ad0
https://ibmwr.org/index.php/k-bike-tech-articles/
This site has all kinds of technical specifications on all the BMW models    http://www.bmbikes.co.uk/mechanicalpages/kseriesmechanical.htm
http://largiader.com
http://bmwk10075abs1fix.web.fc2.com/index.html  Toshi ABS site
Hosa D5S-6 CAIG DeoxIT 5% Spray Contact Cleaner, 5 oz.
CAIG Laboratories D100L-25C Contact Cleaner Needle Dispenser
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline foliver
« Reply #4 on: July 05, 2021, 08:49:25 AM »
Thanks a lot Volador!!
Lot of help I”ll keep this info!!
Fabián
  • Bmw K75C 86
« Reply #5 on: July 05, 2021, 02:24:50 PM »
It's very rare for K front wheel bearings to go bad.
If it ain't broke don't fix it.
Offline foliver
« Reply #6 on: July 05, 2021, 03:50:44 PM »
Hi Frankenduck, if they’re good can i apply grease, or they don’t need maintenance?
Txs!
  • Bmw K75C 86
« Reply #7 on: July 05, 2021, 04:38:40 PM »
Don't need maintenance.
