Author Topic: K75 Engine noise  (Read 54729 times)
Offline bgcameron
Re: K75 Engine noise
« Reply #75 on: April 25, 2021, 08:25:09 AM »
So no light switch but km cluster? Dunno if that's normal for Canadica. How's about photos.
What maintenance history do you know of?
Some internet sleuthing revealed some maintenance history! See the article about splines. Hopefully this link works. If not, I will try to fix it later when I am not posting from my phone.
https://www.google.com/url?sa=t&source=web&rct=j&url=http://static1.1.sqspcdn.com/static/f/760327/10120680/1294422490340/Beemer-Reader-17-09-September-2007.pdf%3Ftoken%3DmUfDhk4UT6LaBs50vL3N690JJFQ%253D&ved=2ahUKEwjV96nysJnwAhWyPH0KHWRFDQQQFjABegQIDhAC&usg=AOvVaw2SZu79ToCsVdlJfSTOSxyh
  • Vancouver Island
  • 1990 K75S
« Reply #76 on: April 25, 2021, 08:45:37 AM »
Is this article by the guy who owned the bike before you?  Here is what splines that get a light coat of HondaMoly 60 every 10,000 miles look like at 98,000 miles(160,000km).
* DSCN3341.JPG (22.8 kB . 609x576 - viewed 597 times)
* DSCN3349.JPG (38.13 kB . 618x576 - viewed 599 times)
If your splines are okay, and they should be after a mere 53,000km, then throw a little lube on them and ride the damn bike.
When you put the drive shaft back in after you do the lube, make sure it's locked into the transmission output shaft.
Offline bgcameron
« Reply #77 on: April 25, 2021, 10:49:40 AM »
  • Vancouver Island
  • 1990 K75S
« Reply #78 on: April 25, 2021, 12:00:48 PM »
My advice is to sell it to me.
« Reply #79 on: April 25, 2021, 12:08:07 PM »
You've got a gen-u-ine BMW comfort seat there, bg. They aren't common but get much better reviews for long distance riding than the OEM bench seats.  112350
Offline daveson
« Reply #80 on: April 25, 2021, 05:24:40 PM »
That's absabloodylutely spotless, I should have known.
How's about the instrument cluster.
Hopefully, as has been said, just needs the cobwebs shaken out of it.
  • Victoria, Australia
Offline bgcameron
« Reply #81 on: April 25, 2021, 05:54:16 PM »
It's actually a reupholstered Corbin. It looks very similar to the comfort seat.
  • Vancouver Island
  • 1990 K75S
« Reply #82 on: April 25, 2021, 06:13:06 PM »
:nono2: We'll need to see its papers. If it was a Corbin, it wasn't reupholstered; it was stuffed.  :laughing4-giggles:
Offline daveson
« Reply #83 on: April 25, 2021, 06:42:40 PM »
All good.
Since you don't have many posts, l looked at them for photos without luck, but noticed at least one valve out of spec. Over max for exhaust, surprising, dunno if you fixed it.
Anyways, it wants a full service and a lot of Kay's.
If you still have the noise, could it be something stupid like a loose air box vibrating? I was chasing a knock in the back of my car once, eventually, eventually I fixed it after emptying the crap out of the trunk. Then repacked it.
Another thing, the annular spring has been under compression for thirty years, regardless of the mileage, it may have lost some tension by now, with the result of a rattly idler gear. Big deal, you don't need an idle gear, you could throw it in the bin (it's only there to reduce noise, if rattly only increases noise.)
Offline bgcameron
« Reply #84 on: April 25, 2021, 07:08:26 PM »
I replaced 2 shims to bring it into spec. One was a hair tight and one was a little loose. I was thinking there might be something loose inside the airbox so I went through it and couldn't find anything.
I've been in touch with a local gentleman who has been riding a K75 since he bought it new in the mid 90's. He's offered some guidance on servicing and thought that the clutch splines are worth looking at.
Is the rattling idle gear the one that tends to make a bit of a zipper type of sound with abrupt revs from idle?
  • Vancouver Island
  • 1990 K75S
Offline daveson
« Reply #85 on: April 26, 2021, 12:22:40 AM »
Dunno.
How's about a video.
I spose the air box idea was wishful thinking on my part, I forgot the handlebar vibrating symptom.
Offline bgcameron
« Reply #86 on: April 26, 2021, 12:49:13 AM »
Found some good info in here: https://www.k100-forum.com/t10397-engine-clatter
It may be a matter of simply retorquing a the clutch housing retaining nut.
  • Vancouver Island
  • 1990 K75S
Offline daveson
« Reply #87 on: April 26, 2021, 06:27:16 AM »
That's why I asked if pressure on the clutch changes the sound, but it didn't, making me back away from the idea.
So probably not a good idea to turf the idle gear in the bin, I forgot about its oil gallery, not that it'll come to that anyway.
What an incredible example of attention to detail by BMW, this oil gallery is. It can only rotate a small amount on its shaft, between two teeth of the driven gear.
Offline bgcameron
« Reply #88 on: April 26, 2021, 06:39:54 AM »
So probably not a good idea to turf the idle gear in the bin,  I forgot about its oil gallery.
Perhaps there is still slight contact between the clutch plates that is enough to agitate that gear in the balance shaft. Regardless, I should do a full spline service anyways and torque that nut while I am in there.
  • Vancouver Island
  • 1990 K75S
Offline daveson
« Reply #89 on: April 26, 2021, 07:27:13 AM »
Yep if the clutch nut turns with your torque wrench at its setting, its been loose.
While you're there,  check that the balance marks are in the right place. There was a thread where an unbalanced clutch caused a noise, but not vibration, surprisingly, maybe since the output/balance shaft turns in the opposite direction to the crankshaft.
Offline daveson
« Reply #90 on: April 27, 2021, 11:04:43 PM »
OK another guess is that reduced tension in the circlip (or it's opened a little) could result in your symptoms, with the result of endfloat on the driven gear and maybe a bit of slop with the idler gear, but only under light load, so while coasting the spring load might be sufficient.
I've added more reasons to your link above.
I think with the crank cover removed you have a small window of access to the driven gear. Probably only useful to check for slop between the drive gear and driven gear pointing to reduced tension from the annular gear. Unlikely, but easy to check for. If there was any endfloat with the key off, you'd think the noise would be at all rpm ranges.
Please chime in if you think this is crap, it could well be, I don't want to waste anyone's time.
Offline daveson
« Reply #91 on: April 28, 2021, 03:13:47 AM »
How the parts interact, this drawing is a k100, but the gears and circlip arrangement is similar. Not exact or to scale, just to help understand it.
Offline bgcameron
« Reply #92 on: April 29, 2021, 04:48:56 PM »
I showed the sound clip to the local BMW expert. He thinks it's the starter clutch. Will start disassembly soon.
  • Vancouver Island
  • 1990 K75S
Offline daveson
« Reply #93 on: April 29, 2021, 04:55:27 PM »
Are you going to open the starter?
Unfortunately there's no clutch in the starter.
« Reply #94 on: April 29, 2021, 05:07:05 PM »
I think he's talking about the spray clutch in the intermediate housing.
Offline daveson
« Reply #95 on: April 29, 2021, 05:17:33 PM »
True.  I was wondering if the BMW workshop is going to disassemble soon or bg is going to open the starter soon, or something else.
Offline bgcameron
« Reply #96 on: April 29, 2021, 08:11:10 PM »
Well, I am hoping to do the work myself. Has anyone here checked this component? It seems like the common issue with it is a no-start condition, but I have not read anything about it making noise.
  • Vancouver Island
  • 1990 K75S
Offline daveson
« Reply #97 on: April 29, 2021, 08:59:41 PM »
What work are you planning on doing? Opening the engine? That's a big job. I'd do some tests first to confirm it's the problem before doing that. Has the starter been working normally, does it sometimes slip? The crank could release the clutch, hard to imagine it could engage it.
If he means the starter is turning the clutch, I'd remove power to it (and insulate) and see if the noise disappears.
« Reply #98 on: April 29, 2021, 09:13:25 PM »
:popcorm
Offline daveson
« Reply #99 on: April 29, 2021, 09:26:53 PM »
Dunno if it's been mentioned yet but removing the alternator might have an effect on the noise.
