Author Topic: Can I replace the cables from the sender to the fuel pump?  (Read 2190 times)
Offline foliver
« on: February 11, 2021, 08:04:49 AM »
Hi, I am cleaning the tank of my K75C 1986, so I take off the fuel level sender.
Lots of rust, but it works.
The cables to the pump, are cracked.
Can I replace them?, any cable of the same diameter can work?
Is the insulation plastic composition important as it will be submerged in fuel?....
Any comments will be appreciated.
Thanks!
Fabian
  • Montevideo, Uruguay
  • Bmw K75C 86
Re: Can I replace the cables from the sender to the fuel pump?
« Reply #1 on: February 11, 2021, 12:56:18 PM »
Most wire has PVC insulation.  It's reasonably fuel proof.
If you want to be really sure, see if you can find #18AWG tinned wire with Teflon insulation.
Offline foliver
« Reply #2 on: February 13, 2021, 07:58:26 AM »
Thanks for your reply Mighty Gryphon!
  • Bmw K75C 86
