Author Topic: K100LT Parts Diagram Question  (Read 5164 times)
Offline Dan87
« on: December 21, 2020, 04:40:39 AM »
Going over my 87' I see I'm going to need to rebuild the water/oil pump due to a coolant drip at the telltale weep hole. Looking at the water/oil pump parts diagram on parts fiche at MAX BMW I see diagrams for two water/oil pumps. At a quick glance the only difference I see between the two diagrams is the oil pump pickup.
How do I know which diagram applies to my 87 K100LT?
  • CT
  • 1987 K100LT
Offline koapono
Re: K100LT Parts Diagram Question
« Reply #1 on: December 21, 2020, 06:48:13 AM »
Greetings,
Usually, upon close examination of parts diagram and component list, you will find a "from" or "to" model year designation for parts that have changed or been modified.
If that's not the case then call MAX with pertinent date: year, model, VIN and they will set you straight.
I have found them to be very helpful and eager to get you the right part.
g'luck
  • 1994 K1100LT
« Reply #2 on: December 21, 2020, 02:24:47 PM »
All the seals, bushings, impellers, shafts and other parts recommended for rebuilding your pump have the same part numbers in either diagram. It can be a costly undertaking. Whether the pump needs a new shaft will be determined when you inspect it; however, many of them are pitted beyond the ability to salvage.
  • 1995 K75 89,000 miles
Offline Billk
« Reply #3 on: December 30, 2020, 07:42:24 PM »
Try Euroelectric.com
Comes with a tool to seat
the seal. They take phone
calls
  • NYS
Offline Dan87
« Reply #4 on: January 20, 2021, 06:08:54 AM »
Thanks all. thinking about the age of the bike and the miles on the clock I set out to but together a parts list for rebuilding the water/oil pump. Working with MAX BMW I found for just a few more bucks I could order a new pump. Thinking about the time that would go into rebuilding and not knowing for sure if it was successful until installation I opted for buying new. I should have it in a week or two.
  • CT
  • 1987 K100LT
Offline RobP
« Reply #5 on: January 20, 2021, 08:57:19 AM »
Quote
Should be https://www.euromotoelectrics.com/
  • Driftwood, TX
  • 1985 K100RS
Offline Dan87
« Reply #6 on: January 22, 2021, 05:28:26 AM »
Thanks for the link RobP. I added it to my Parts Supplier list.
  • CT
  • 1987 K100LT
