Author Topic: Help! K100rs headight bulb plunges in out?why?burned out?  (Read 2641 times)
Offline Blue85
« on: October 28, 2020, 09:58:16 PM »
Ok new k100rs owner.p.o said he installed a new (super) headlight... ok got the bike headlight not working. Pulled plug out of housing when switching hi/ lo beam it pulls the bulb in and out? What? Filament seems cloudy ash grey...first is this a special bulb? Second i have no idea if its burned out. Bike was laid down but no evidence of wire damages etc...
  • Coloma Wisconsin
  • 1985 k100rs
Happiness is a little yellow bird tweeting in a open field...
Re: Help! K100rs headight bulb plunges in out?why?burned out?
« Reply #1 on: October 28, 2020, 10:12:31 PM »
Some photos would be helpful to fill out your description, Blue, and to identify the bulb type and printing on the bulb's body.
« Reply #2 on: October 28, 2020, 11:06:43 PM »
If the bulb is high power halogen, it will draw greater current through the handlebar switches.  That extra current could heat up the switches which will melt and fail.  Recommend to
- examine the bulb electrical characteristics to see if it draws more than 55W
- examine the switches for heat damage and repair
- seriously consider an Eastern Beaver headlight relay kit
Offline Blue85
« Reply #3 on: October 28, 2020, 11:45:29 PM »
Ill post accurate pics tomorrow.thanks
  • Coloma Wisconsin
  • 1985 k100rs
Offline Blue85
« Reply #4 on: October 31, 2020, 09:35:30 AM »
* 3DF20404-AD22-4740-8C57-4A224173D062.jpeg (94.86 kB . 768x576 - viewed 433 times) Found the culprit! This converter box had this rattling around inside broke off.put a standard bulb back in  light on!.... now on to sticky throttle and front brake....🧐
  • Coloma Wisconsin
  • 1985 k100rs
« Reply #5 on: October 31, 2020, 09:41:50 AM »
 icon_cheers
Offline alabrew
« Reply #6 on: October 31, 2020, 02:30:56 PM »
That sounds like the HID set I had in the F150 with single bulbs for hi/lo.
The HID bulb moved in and out with a magnet to give hi/lo.
Didn't work very well since the headlights were not designed for HID.
I put a HID set on the K12LT and it works pretty well since it is a two light setup.
The 525i has factory Active Xenon headlights and moves the lens to give hi/lo (and follow the steering wheel).
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
