Author Topic: K1100 v K100  (Read 5788 times)
Offline Cafe racer
  • Café racer
K1100 v K100
« on: October 02, 2020, 07:53:11 PM »
Considering buying a K1100LT 60km.
Are these better than the K100?
What are the main improvements, I see in the photo, that it has the torque arm on the driveshaft.
Any know issues that the K100 doesn't have?
Any comments much appreciated.
  • Japan
  • K100RS 1988 2 valve
Re: K1100 v K100
« Reply #1 on: October 02, 2020, 08:45:44 PM »
In my opinion, K1100 is an all 'round better choice than the K100.  Still as reliable as an appliance, just like the K100.
Re: K1100 v K100
« Reply #2 on: October 02, 2020, 09:58:39 PM »
4 valve instead of 2 valve, better brakes, newer FI, Paralever rear, more HP, 2nd gen ABS (after 1993) yeah, go for the 1100
Offline Cafe racer
  • Café racer
Re: K1100 v K100
« Reply #3 on: October 02, 2020, 10:58:56 PM »
without knowing the year, can I tell if 2nd gen ABS visually
  • Japan
Re: K1100 v K100
« Reply #4 on: October 03, 2020, 12:57:22 AM »
On models with ABS 2 there is one pressure regulator that isn't easily visible so your photo is of a 1994 or later model.
If a K1100 has ABS 1 you'd see a cylindrical pressure modulator above the footpeg plate on each side—like the one in the photo below.
Approximate weights according to Phil Hawksley's BMBikes site:
1988 K100RS 249kg
K1100RS 268kg
K1100LT 290kg
Offline koapono
Re: K1100 v K100
« Reply #5 on: October 04, 2020, 04:17:51 PM »
not BETTER, just different!
I have an 85 K100RS and a 93 K1100LT, love them both but they each have their own personality.
The RS with short bars and "sort of" forward leaning riding position has that speed-racer feel to it. Requires a little more effort to turn and flow with the twisties although effort diminishes as speed increases. Tis the reason for a folder full of speeding tickets.
The LT is an all-day rider! Designed for the long haul. If you buy it, throw some radials on it and you'll swear you're riding a brand new bike as compared to the RS.
Keep both if you can but if you must choose I'd go with the LT only because I'm old and decrepit. I've become more a tourer than a peg dragger.
g'luck
  • 1994 K1100LT
Offline Cafe racer
  • Café racer
Re: K1100 v K100
« Reply #6 on: October 04, 2020, 05:35:53 PM »
koapono, many thanks, I love the riding position the RS, previous bikes have been S1000RR and two S1000R's
Bike before the KRS was a R1150 Rockster, awesome riding position, but it was a hot bike in the 35degC plus weather.. and thirsty for the engine oil. So you can see my bikes are getting older, so am I (61)
  • Japan
Offline Skunky
Re: K1100 v K100
« Reply #7 on: October 04, 2020, 06:25:01 PM »
Cafe Racer. If (as your pseudonym suggests), you are intending to build a cafe racer the K1100 is a better choice. The 4 valve has a different fuelling system from the 2v which allows you to replace the air box with pods or cone filters etc. It's slightly more refined than the K100's and tends to sell for a little more money.  As for riding position you buy a bike and pick your own. Either way these are great bikes with unbreakable engines. I love mine
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
Offline Cafe racer
  • Café racer
Re: K1100 v K100
« Reply #8 on: October 05, 2020, 08:58:07 AM »
Skunky, Not sure of my plans with the bike, will know more after this wednesday when I pick it up... my solo riding style is RS, but with my lady on the back maybe the LT.. if its made into a cafe racer... so be it..
  • Japan
Offline Cafe racer
  • Café racer
Re: K1100 v K100
« Reply #9 on: October 11, 2020, 08:02:09 PM »
Thanks for the comments the bike turned out to be very rough, the clutch was slipping in all gears on the flat when accelerating. So I didn't buy it...
  • Japan
Offline Past-my-Prime
Re: K1100 v K100
« Reply #10 on: October 12, 2020, 08:29:15 PM »
What's a new clutch run for one of those? $350?  Plus you get to check the splines. . .
Re: K1100 v K100
« Reply #11 on: October 12, 2020, 08:43:17 PM »
clutches are easy on these bikes.  and, as mentioned, ya gotta do the splines anyway....and the clutch o-ring, and the rear main seal.   its all one afternoons worth of work.
Re: K1100 v K100
« Reply #12 on: October 12, 2020, 08:50:29 PM »
Might just be an adjustment.
Offline Cafe racer
  • Café racer
Re: K1100 v K100
« Reply #13 on: November 03, 2020, 12:25:40 AM »
thanks to all for comments
  • Japan
Offline warmshed
Re: K1100 v K100
« Reply #14 on: January 15, 2021, 11:13:24 AM »
The paralever makes the bike handle much better
  • london
  • K1
