I had considered that to be honest, do all the prep and just take the parts to a guy to paint. This is CR, it would probably cost me $200 to have them do base coat and clear - it feels like a cop out though. I am stuck in the house for the next God only knows how long, seems like a good time to screw up and learn from my mistakes...
Have you ever done a paint job before? Gun control on a big flat object like the side of a car is one thing, but smaller complicated stuff like the fairing lowers can be sort of tough to get clear to flow out without runs or sags. You gotta keep moving, but not too fast. Stop for a second and you have a big run down the part, go too fast and the surface will look like 80 grit paper.
You can almost get away with murder putting down the base. Just be patient and do a lot of light coats, but clear has to be wet. That's where someone who does it every day has the advantage of experience.
Do the prep, prime everything, make the parts perfect and shell out the cash for a pro job. Then strip the frame and do a really good job on it. Detail every bit you take off, it will keep you plenty busy. A proper job can keep you busy well after your incarceration has ended.
