Author Topic: Travel Trunk Latche?  (Read 24580 times)
Offline schrocketeer
« on: March 28, 2020, 02:46:17 PM »
What is the travel trunk latch supposed to look like?
A previous owner had used wood screws, an aluminum block, and latch from a Samsonite suitcase. Ugly as it was, it was mainly functional, but then the JB Weld holding the aluminum spacer block came loose. Yes, I did try to re-JB-Weld it, to no avail.
I'm not really that concerned with the ability to lock it. However I'm open to suggestions for something better than the previous hack I used involving a tie-wrap (zip-tie, etc.).
  • North Alabama
  • 1985 K100RT very original
Ken
Re: Travel Trunk Latch?
« Reply #1 on: March 28, 2020, 02:55:39 PM »
I'd like to help, but the photos make it impossible to see what you have.  Doesn't look like the iconic 22 liter.
Offline natalena
« Reply #2 on: March 28, 2020, 03:34:09 PM »
I've used a window 180* flip latch, the kind that cams tight at the end of the throw. Easy to install, although it looks like some JB or fiberglass would help smooth and strengthen your work surface ;) Good Luck
  • MST
« Reply #3 on: March 28, 2020, 03:47:44 PM »
If it's the one in this photo from one of your threads, it isn't OEM.
* aftermarket top case.png (826.11 kB . 768x432 - viewed 1736 times)
« Reply #4 on: March 28, 2020, 07:06:53 PM »
Is that a Reynolds rack under the case?  Did Reynolds make cases?  Are they still in business?  That may be a good place to look.
« Reply #6 on: March 28, 2020, 09:49:08 PM »
My K has an embarrassing amount of Lowes and Home Depot hardware on it.  Usually hold up better than the pricey BMW stuff.
Agree Agree x 2 View List
Offline Past-my-Prime
« Reply #7 on: March 28, 2020, 11:19:03 PM »
Thank you Home Depot.
Actually, I've ordered from BMW a replacement and that's on my list of maintenance once it warms up a bit more here.
Offline kioolt
Re: Travel Trunk Laitch?
« Reply #8 on: March 29, 2020, 10:39:01 AM »
That a Luftmeister trunk.  I've got one on my 82 R100RT.  I replaced the laitch once way back.  I was able to get it from the dealer at the time.  Luftmeister is now out of business as far as I know.  Here is a current eBay listing of a Luftmeister trunk showing the laitch.
https://www.ebay.ca/itm/BMW-Luftmeister-Top-Case-Airhead-R60-R75-R90-R90S-R100-Daytona-orange-NOS/192930481731?hash=item2ceb8d8643:g:F7MAAOSwlqZc6~ro&vxp=mtr
« Reply #9 on: March 29, 2020, 11:12:04 AM »
Good news!  That case uses a Zero Aluminum case laitch.  And Zero is still around to supply parts.
Customer Service:  https://zerohalliburton.com/pages/customer-service
* zero case.jpg (34.27 kB . 768x510 - viewed 1707 times)
Offline mw074
« Reply #10 on: March 29, 2020, 01:20:29 PM »
Here you go.
  • Michigan
Offline volador
  • NEEDS MORE CHROME
« Reply #11 on: March 29, 2020, 01:59:38 PM »
Here you go.
What mounting base is required for that K100 LT case?
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline mw074
« Reply #12 on: March 29, 2020, 02:18:08 PM »
I have seen 2 different versions. One has it's own tubular frame that mounts several places to the bike. The other has studs that go into the tail section where the stock luggage rack mounts. Both styles the boxes are the same, other than the studs installed. They just mount differently.
  • Michigan
« Reply #13 on: March 29, 2020, 02:47:11 PM »
Here you go.
Brilliant, mw!
An earlier style latch assembly can be used—either front-and-center, or one on each side of the front, after the surfaces have been repaired. A plate of sufficient thickness would need to be mounted under the laitch on the case to align it with its catch on the lid but that would be easy enough. Longer rivets would be needed.
Offline kioolt
Re: Travel Trunk Latche?
« Reply #14 on: March 29, 2020, 03:47:53 PM »
« Reply #15 on: March 29, 2020, 05:34:08 PM »
the rv hardware section of rv superstoars have all kinds of laitches... just saying...
Offline mw074
« Reply #16 on: March 29, 2020, 05:44:15 PM »
Use of the OEM BMW latch allows it to be keyed alike to the rest of the bike.
  • Michigan
« Reply #17 on: March 29, 2020, 06:46:07 PM »
There doesn't seem to be a lot of variations in tragkorb/top box keys. I've checked two of my mates keys and both will open my tragkorbs. I bought a heap of Brick parts the other day with a set of tragkorbs and a top box my keys will open the tragkorbs but not the top box. When we get to socialise again I'll have to check a few more Bricks.
Offline mw074
« Reply #18 on: March 29, 2020, 07:12:02 PM »
That translates into the ignition switch ( key and tumblers ) being that easy to breach also.
  • Michigan
« Reply #19 on: March 29, 2020, 09:41:01 PM »
No I could unlock the tragkorbs but not the ignition.
Regards Martin
