Author Topic: K1 GAS CAP BITS  (Read 5849 times)
Offline zigyphoto
  • WHAT YOU SEEK IS NOT IN YOUR PHONE
K1 GAS CAP BITS
« on: February 21, 2020, 09:23:43 PM »
Wanted to remove the gas cap assembly on my 1990 K1 to replace the seals and gaskets, but could not get the entire assembly out (probably stuck to rubber seal under it) so just removed the part underneath the cap itself.
When I finally managed to get the conical piece that fits down into the gas tank opening, the bits inside it popped out.
Not sure which way the two interior pieces fit back in.
Oddly enough, this piece and associated gasket seems unique to the K1; the good vid showing how to disassemble and rebuild the gas cap on a K100 -- https://www.euromotoelectrics.com/product-p/ft-gasketkit461.htm -- does not show this piece.
So, wise ones, who can help me get this superb piece of Teutonic engineering back together correctly?
See pix:
1: gas cap upside down with pieces in question
* IMG_4542.jpg (59.83 kB . 555x576 - viewed 701 times)
2. with piece inserted one way (gasket goes on top or underneath?)
* IMG_4543.jpg (63.22 kB . 768x576 - viewed 750 times)
3. piece inserted other way (gasket goes where?)
* IMG_4544.jpg (56.33 kB . 768x576 - viewed 703 times)
thanks,
z
  • Boulder CO
  • 1990 K1 (& 2016 R1200GS-LC and R1200GS in Germany)
PAY ATTENTION AND BE ACCOUNTABLE
Re: K1 GAS CAP BITS
« Reply #1 on: February 21, 2020, 09:29:46 PM »
Please show the top, key side of that cap.
Offline zigyphoto
Re: K1 GAS CAP BITS
« Reply #2 on: February 21, 2020, 09:37:00 PM »
* IMG_4546.JPG (35.17 kB . 768x576 - viewed 771 times)
* IMG_4550.JPG (48.5 kB . 768x576 - viewed 732 times)
  • Boulder CO
Re: K1 GAS CAP BITS
« Reply #3 on: February 21, 2020, 09:46:12 PM »
The K1 and the later models of K100, and K75 all have the same cap—16111453641. The early model push-button caps were prone to vapor lock. Yours doesn't seem to have the same latch configuration as mine, which is like the one in the video. Compare yours.
Does yours open using just the key or do you also need to push on the key cylinder?
Offline zigyphoto
Re: K1 GAS CAP BITS
« Reply #4 on: February 21, 2020, 10:06:54 PM »
Mine opens with just key turn.
The issue is not the cap per se; it is the interior bits under the conical part that goes down into the opening.
Watching his vid, no parts like mine when he gets that conical cap off with the adjustable wrench.
z
  • Boulder CO
Re: K1 GAS CAP BITS
« Reply #5 on: February 21, 2020, 10:18:39 PM »
The cap is the sum of its parts.  :laughing4-giggles:
As I indicated, the K1 and the late model K75/K100 models all have the same part number for fuel caps which means they are identical.
Looking at your photos, I would place the triangularly configured, vented part facing the fuel tank's interior, the gasket beneath it and the cover over it. If that created fume problems, I'd reverse it. If that didn't work either, I'd find a later model cap.
This is one of those times when following procedure rather than acting extemporaneously when encountering difficulty, then paying attention might have made things slightly easier but it's not the end of the world. The plastic parts look slightly worn. Is the tank's interior clean?
Offline zigyphoto
Re: K1 GAS CAP BITS
« Reply #6 on: February 21, 2020, 10:37:09 PM »
 I've had my moto's fuel cap disassembled right down to to the lock spring mechanism and didn't come across that part. You might have a bitsa.
don't know that term, but seems useful.  Definition?
thank you
I appreciate your continued assistance; however, don't appreciate the judgement and lecturing. Had I found a procedure, I would have used it; spent a good 1/2 hour attempting to follow the method shown in the video to no avail.  Finally understood the conical gizmo popped off, not unscrewed.
Tank's interior is brilliantly clean.  I cleaned the small internal bits in photo once I saw the dirt in the pix; now spit-polished clean.
Signing off for the evening, and thanks again.
z
  • Boulder CO
Re: K1 GAS CAP BITS
« Reply #7 on: February 21, 2020, 10:53:04 PM »
A bitsa is a mostly British term meaning bits a this and bits a that.
You aren't the first to fail to appreciate my lecturing, although I really didn't get started at that.  :laughing4-giggles:   Nevertheless, you're well on your way to cracking this mystery. Somebody with more equanimity at hand is bound to take up your cause.
Good luck.
Offline zigyphoto
Re: K1 GAS CAP BITS
« Reply #8 on: February 22, 2020, 12:28:23 PM »
Laitch,
thanks again.
There is nothing I appreciate more than a man who is willing to listen and be accountable even for unintended consequences (as am I for screwing this up!).
As always, what we say isn't as powerful as the way we say it; has taken me years to get that...
fyi,
I'm on ADVrider Tent Space list, so if out here always welcome to a bed.
z/Boulder
  • Boulder CO
Offline alabrew
Re: K1 GAS CAP BITS
« Reply #9 on: February 22, 2020, 02:27:09 PM »
Have you watched the Chris Harris youtube video on rebuilding that cap?
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
Offline zigyphoto
Re: K1 GAS CAP BITS
« Reply #10 on: February 22, 2020, 11:24:27 PM »
I did, and his gas cap did not have the internal bits that were causing my confusion.  Someone sent me pix of his disassembled showing which way those bits went in.
Now to keep trying to loosen the entire cap from tank.
Have sprayed with silicone and still (gently) trying..
thanks for the suggestion.
z
  • Boulder CO
