Hi everyone! I followed some of Laitch's advice but i have bad news
Spark Plugs were set somewhere around 0,6&0,65
These are the compression tests I did:
| Test | Cylinder 1 | Cylinder 2 | Cylinder 3 |
| Without adding oil | 75 PSI | 0 PSI | 150 PSI |
| Adding 5cc of oil to each cyl | 100 PSI | 0 PSI | 160 PSI |
As you can see, cylinder #2 is dead, and cylinder #1 is low on compression.
regarding the valves I measured the following clearances:
| Inlet | 0.15-0.20 | 0.15-0.20 | 0.15-0.20 |
| Exhaust | 0.20-0.25 | 0.25-0.30 | 0.15-0.20 |
As far as I understand I have to change the shims on the exhausts valves of cylinders #1 and #3
I am thinking I will have to dismantle the head of the engine and check the condition of the head gasket, hopefully my its not the piston rings.
What would you do?
