Author Topic: K75 neglected for two years  (Read 23168 times)
Offline Rokah
« on: October 14, 2019, 06:46:11 AM »
Hi, I've been gifted with a '90 K75 that doesn't start. I don't know much about it, except that one day the bike stopped and the owner never bothered to fix it. It's been two years since that...
General state: Bad. broken foot rest plates (PNs 46711457234 & 46711454485).  Bent back brake foot lever. Rusted forks. Rusted gearbox oil plug (07119919143). Broken headlight glass. Bent front brake lever & handlebar. Cracked vacuum plugs (13547694924)
Rust in the battery strap (and installed incorrectly): PN 61211459044
Sulfate in battery holder and rusted Vibration dampers (PN61211233028 )
Petrol tank installed incorrectly, missing (PN 16112309163) vibration dampers and missing retention clips PN07129934336
Battery: around 5. (The clock is still running though)
Brakes. Front brake works, back brake doesn't. The reservoir is empty
Coolant level: low
Oil level: On the lowside but still has some.
Spark plugs: horrible condition, they had screw terminals and I believe this bike had a solid terminals (Bosch X5DC or NGK D7EA)
Fuses: all OK
The goal is to make it start before doing anything else; I have the feeling the last guy who worked on this bike didn't have a clue on what he was doing.
  • Madrid
  • K75
Offline Rokah
Re: K75 neglected for two years
« Reply #1 on: October 14, 2019, 06:46:31 AM »
I've purchased a new battery (EXIDE GEL 12V 19AH GEL12-19) and new spark plugs. they have been tested by connecting them to the HV leads and grounding them to the chassis. they all make a blue spark. Injectors have been removed from the throttle bodies and they all spit petrol. The bike still won't start
However, it now cranks with force and Injectors spit fuel
Bottom line: electrical systems seems in top condition and grounding of the battery looks ok.
I think the next step I will take is to remove all fuel in the fuel lines/injector rail.
What do you think I should test next? Fuel pressure or compression? Should I go directly for the compression test?
  • Madrid
  • K75
« Reply #2 on: October 14, 2019, 08:08:43 AM »
Fix all these faults you have found, especially the vacuum leaks. Put a bit of oil in the cylinders to improve sealing. Give it a service.
Offline Rokah
« Reply #3 on: October 14, 2019, 09:00:57 AM »
Will do!
Is this a regular cranking noise?
https://photos.app.goo.gl/ikKFshWSoBtZCKnE7
  • Madrid
  • K75
« Reply #4 on: October 14, 2019, 09:25:41 AM »
Is this a regular cranking noise? Should I go directly for the compression test?
The sound it makes during starting is not unusual. Limit the duration to five seconds. Disconnect the battery or connect it to a tender when you aren't working on the moto.
A compression test is uncomplicated. Do it. Check each cylinder with the throttle wide open. After the first reading of a cylinder, repeat after spraying some oil into the cylinder to see if that raises its value significantly.
Top up the coolant. Change the oil and filter. The fuel tank should be cleaned. The fuel filter should be replaced. The tank interior fuel lines should be replaced with new 30R10 lines. The valve clearances should be checked and adjusted if necessary. The new spark plugs' gaps should have been checked before installation. The air intake and filter should be checked for restrictions; the muffler outlet should be checked for restriction. The z-tube crankcase-to-airbox connection should be checked that it isn't severed.
After doing all that, try starting it.
« Reply #5 on: October 14, 2019, 11:30:38 AM »
exactly what he said....perfect pre-start checklist.
Offline Soggz
« Reply #6 on: October 14, 2019, 12:17:20 PM »
Good Luck. Mine was neglected since 2008.Getting there though.
  • Down in Selwood Forest
Offline Rokah
« Reply #7 on: October 18, 2019, 12:46:11 PM »
Hi everyone! I followed some of Laitch's advice but i have bad news
Spark Plugs were set somewhere around 0,6&0,65
These are the compression tests I did:
TestCylinder 1    Cylinder 2    Cylinder 3
Without adding oil75 PSI0 PSI150 PSI
Adding 5cc of oil to each cyl100 PSI0 PSI160 PSI
As you can see, cylinder #2 is dead, and cylinder #1 is low on compression.
regarding the valves I measured the following clearances:
Inlet0.15-0.200.15-0.200.15-0.20
Exhaust     0.20-0.250.25-0.300.15-0.20
As far as I understand I have to change the shims on the exhausts valves of cylinders #1 and #3
I am thinking I will have to dismantle the head of the engine and check the condition of the head gasket, hopefully my its not the piston rings.
What would you do?
  • Madrid
  • K75
« Reply #8 on: October 18, 2019, 01:10:27 PM »
What would you do?
I don't understand your measurement results. There should be one value for each valve, not a spread of values. Because these figures don't make sense, I wonder if your compression technique might be flawed also
Explain exactly how you tested the compression and exactly what type of tool you used to perform the test.
Offline Rokah
« Reply #9 on: October 18, 2019, 01:30:47 PM »
Sorry I didn't explain. My gauges go in 0.05mm increments, the first value I was able to fit and the second I wasn't, therefore I know the gap must rely somewhere between the two values.
Compression I measured using this https://www.amazon.es/gp/product/B074CT56FF/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1. Removed all the sparkplugs, and then fitted the gauged and cranked the engine with the throttle open until the gauge reached a maximum. Then, repeated for the rest of the cylinders
  • Madrid
  • K75
« Reply #10 on: October 18, 2019, 01:57:09 PM »
OK. All the intake valves are good. #1 and #3 exhaust valves need adjustment.
You need to do a leak-down test if you don't have a camera like the one in the attached video that can look around via the spark plug hole. These cameras are surprisingly inexpensive. They are called borescopes. #2 and #1 might have severely damaged valves and/or valve
seats.
Offline Rokah
« Reply #11 on: October 18, 2019, 02:21:01 PM »
Do you think its worth testing? I mean, i know there must be something wrong with the valves. I might as well just disassemble  the engine head and take a look with my own eyes and fix it while its open. Don't you think?
Thanks for the help!
  • Madrid
  • K75
« Reply #12 on: October 18, 2019, 02:26:36 PM »
I'm guessing that you have some burnt exhaust valves.
If it were mine, I'd pull the head and take a good look.  If there's damage, I'd be looking for a used head at ebay and a new head gasket.
« Reply #13 on: October 18, 2019, 02:51:28 PM »
I agree. The odd part is valve clearance is good on the worst cylinder. There could be broken valve springs in the mix.
Take your time. Use plenty of heat, penetrant and impact on the head bolts before attempting to loosen them.
Offline Rokah
« Reply #14 on: October 18, 2019, 03:40:27 PM »
yuuuuuup that I find weird as well! I'll get back with updates!
  • Madrid
  • K75
« Reply #15 on: October 18, 2019, 04:06:54 PM »
Make very sure you have a new tight fitting Torx wrench of the proper size to remove the head bolts. There are two types of Torx wrench, regular and heavy.  Later model bikes use the heavy.   The head bolts have a lot of torque on them, and the heads are easy to strip out.
You don't need to know how I know this.
Offline Rokah
« Reply #16 on: October 30, 2019, 05:33:35 AM »
I doged that bullet!
It looks like I've found the reason for the missing compresion on cyl#2
should I worry on how bad the cylinders look?
To replace the valves, should I replace all of them, or can I just replace the broken one/ones?
  • Madrid
  • K75
« Reply #17 on: October 30, 2019, 09:00:57 AM »
 Cylinder #1 compression is poor; the reason should be sought.
« Reply #18 on: October 30, 2019, 10:00:05 AM »
you sparker orientation looks like a you gotts a low and a high simotaniously on the weather map...
that caint be good...
* 20191030_085315.jpg (32.12 kB . 324x576 - viewed 857 times)
« Reply #19 on: October 30, 2019, 11:03:57 AM »
omg :-)
« Reply #20 on: October 30, 2019, 11:43:42 AM »
The difference in compression values after adding oil is probably symptomatic of stuck piston rings, which happens after neglect and usually ends after the engine is run in again.
Offline Rokah
« Reply #21 on: October 30, 2019, 12:20:31 PM »
omg :-)
Calm down gents, those spark plugs are loose! I put them in just to take the picture.
I'm going to buy a new valve and get a quotation for a head and valve resurface
Any more suggestions?!
  • Madrid
  • K75
« Reply #22 on: October 30, 2019, 12:53:49 PM »
Does anyone index spark plugs anymore?  Does it even matter?
« Reply #23 on: October 30, 2019, 01:55:59 PM »
greetings grandpa...
it matters... thats why i use e3 exclusively...
that and 10 moar horsepower with diamondfior technology...
thats 2.5hp a hole... you would getts 7.5hp combined on your minibrick.. itsa game changer for sure...
* Screenshot_20191030-125443.jpg (30.66 kB . 403x576 - viewed 881 times)
« Reply #24 on: October 30, 2019, 04:14:35 PM »
do they make them for chippers?  mine bogs down with fat people
