Author Topic: Venhill Clutch and Gas Cable Kit?  (Read 3870 times)
Offline Gr-Racing
« on: September 23, 2019, 11:03:22 AM »
hi I need new clutch and gas cable for my new controls I just order the venhill kits.. any tips?
thanks
  • GA
  • K75
Offline volador
  • NEEDS MORE CHROME
Re: Venhill Clutch and Gas Cable Kit?
« Reply #1 on: September 23, 2019, 12:19:02 PM »
Lube the nipples
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #2 on: September 23, 2019, 03:41:29 PM »
Check the lever for excess wear. Fit a grease nipple to the clutch arm.
Offline volador
  • NEEDS MORE CHROME
« Reply #3 on: September 23, 2019, 05:32:26 PM »
Clutch lever/cable perch related parts to consider:
Clutch lever nylon sleeve bushing 32721451796
Clutch lever nipple holder 32721233550
Felt Ring (may or may not be included with OE cable): feltring 32721231610
Felt Ring slides into the cable adjuster, shaped more like a very small dowel then a ring
Clutch cable adjustment procedure
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/clutchadjust/clutchadjust.htm
Curing sloppy clutch and brake levers
  • NYC NY
Offline volador
  • NEEDS MORE CHROME
« Reply #4 on: September 23, 2019, 05:49:39 PM »
Throttle twist grip tube and cam disc have alignment marks
New and improved cam disc 32721457036 requires cover 32721457037
Throttle Adjust http://www.bmw-k100rt-page.eu/manual/FuelOil/18_FuelLub.htm
as per Inge:
The throttle cable have been changed two times...first version have a adjustement sleeve ~halfway length,
second version have a black plastic collar at the lower end...third version have a white plastic collar.
All inner cables have different length and a different lower bracket.....which can't be mixed.
  • NYC NY
Offline stokester
« Reply #5 on: September 23, 2019, 08:42:11 PM »
I found the Venhill clutch cable to be a bit thicker than the OEM but it fit and works fine.
Be sure to clean and lube the clutch lever barrel during installation and regularly after that.
  • Yorktown Virginia
