Venhill Clutch and Gas Cable Kit?
Topic: Venhill Clutch and Gas Cable Kit? (Read 3868 times)
Gr-Racing
^ Motobrick Curious
September 23, 2019, 11:03:22 AM »
hi I need new clutch and gas cable for my new controls I just order the venhill kits.. any tips?
thanks
GA
K75
volador
NEEDS MORE CHROME
Re: Venhill Clutch and Gas Cable Kit?
Reply #1 on:
September 23, 2019, 12:19:02 PM »
Lube the nipples
NYC NY
1991 K100RS 1993 K75S ABS
5 BOROUGHS SISYPHEAN SOCIETY MAINTAINING THE OBSESSION
Martin
Reply #2 on:
September 23, 2019, 03:41:29 PM »
Check the lever for excess wear. Fit a grease nipple to the clutch arm.
North Lakes Queensland Australia
1992 K75s Hybrid, Lefaux, Vespa V twin.
volador
NEEDS MORE CHROME
Reply #3 on:
September 23, 2019, 05:32:26 PM »
Clutch lever/cable perch related parts to consider:
Clutch lever nylon sleeve bushing 32721451796
Clutch lever nipple holder 32721233550
Felt Ring (may or may not be included with OE cable): feltring 32721231610
Felt Ring slides into the cable adjuster, shaped more like a very small dowel then a ring
Clutch cable adjustment procedure
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/clutchadjust/clutchadjust.htm
Curing sloppy clutch and brake levers
NYC NY
volador
NEEDS MORE CHROME
Reply #4 on:
September 23, 2019, 05:49:39 PM »
Throttle twist grip tube and cam disc have alignment marks
New and improved cam disc 32721457036 requires cover 32721457037
Throttle Adjust
http://www.bmw-k100rt-page.eu/manual/FuelOil/18_FuelLub.htm
as per Inge:
The throttle cable have been changed two times...first version have a adjustement sleeve ~halfway length,
second version have a black plastic collar at the lower end...third version have a white plastic collar.
All inner cables have different length and a different lower bracket.....which can't be mixed.
NYC NY
stokester
^ SuperNatural Motobricker
Reply #5 on:
September 23, 2019, 08:42:11 PM »
I found the Venhill clutch cable to be a bit thicker than the OEM but it fit and works fine.
Be sure to clean and lube the clutch lever barrel during installation and regularly after that.
Yorktown Virginia
'94 K75S Dakar Yellow - '93 K75S Seiden Blau - '91 R100RT Bermuda Blue- '78 R100S Smoke Red
