Rectangular upward facing locks on Gen1; cylindrical inward facing locks on Gen 2; cylindrical outward facing locks and larger interior volume on Gen 3. Ted Verrill explains more here.
I was after the 22 litre top box.
That's it. It looks like it has its locking pin. Do you have the mounting plate that fits on the rack? That is a necessary part.
This.
How does it mount onto the rack then?
This is the This of the previous post after magnification. Knock that out in a couple of minutes using an old biscuit tin. top case mounting plate.png (369.4 kB . 472x560 - viewed 739 times)It snaps into place on a rack designed to accommodate it.
The mounting plate fits under the OEM luggage rack. The box is then held on by the twist lock pin inside the box,
$66.89
Indeed. If that can't be reproduced at a fraction of its cost by one of Her Magesty's loyal subjects using tin snips, a biscuit tin and a teacup full of spliffs, the world is indeed off its axis.
As per requested, the first one I bought has a manufacture date August 1985. I replaced four of the original rivets with bolts due to the plastic tab inside the box that holds the lid restraint system being broken off. I also added a bit off para cord as a precaution. The hinge looks to be original it has a metal reinforcing strip on the inside of the box to stop the rivets pulling through, this strip is not on the later box. The second top box with the metal hinge was manufactured in May 1986. A mate has a couple of 22Lt boxes but I believe they are a lot later in manufacture, I'll check when I can.Regards Martin. 22Lt Top box hinge..jpg (41.19 kB . 768x576 - viewed 710 times) 22Lt Top box Lid Restraint.jpg (49.91 kB . 768x576 - viewed 644 times)
