Author Topic: Storage  (Read 9553 times)
Offline Soggz
Storage
« on: August 13, 2019, 01:09:43 PM »
tragkorbs and 22litre top box K75. Are there any difference between ‘1st generation’ ones, and ‘ 2nd generation’ ones? as a set has come up. My bikes an 86.
  • Down in Selwood Forest
Re: Storage
« Reply #1 on: August 13, 2019, 01:45:32 PM »
As far as I can tell, both generations hang on the same mounts.  The difference seems to be the handles and which way the locks face.  Gen 1 faces in and gen 2 faces out.
Re: Storage
« Reply #2 on: August 13, 2019, 02:47:43 PM »
Rectangular upward facing locks on Gen1; cylindrical inward facing locks on Gen 2; cylindrical outward facing locks and larger interior volume on Gen 3. Ted Verrill explains more here.
Re: Storage
« Reply #3 on: August 13, 2019, 03:35:36 PM »
I've got two 22Lt top boxes, one has a plastic hinge similar to the tragkorb hinge. The other one has a metal hinge which appears to be a better proposition.
Regards Martin
Offline Soggz
Re: Storage
« Reply #4 on: August 14, 2019, 02:22:24 AM »
Thanks. Great link.
Offline Soggz
Re: Storage
« Reply #5 on: August 14, 2019, 02:24:15 AM »
My bike came with the gen 1 strays. I was after the 22 litre top box. I’m not too bothered about the side cases, as the ones that came with the bike are ok
Re: Storage
« Reply #6 on: August 14, 2019, 07:56:07 AM »
There seems to be only one version (generation) of the iconic 22lt top case. Mine and all the examples I've seen in original condition have metal exterior cover hinges and locking, cylindrical push-button–operated latches that hook to wire bails attached to the ceiling of their covers. I'd like to see an example of an original 22lt case with a plastic side case–style hinge. That seems like a bodge to me. Maybe Martin will post a photo of his.
Offline Soggz
Re: Storage
« Reply #7 on: August 14, 2019, 09:37:02 AM »
Is this it?
Re: Storage
« Reply #8 on: August 14, 2019, 09:46:49 AM »
That's it. It looks like it has its locking pin. Do you have the mounting plate that fits on the rack? That is a necessary part.
Offline Soggz
Re: Storage
« Reply #9 on: August 14, 2019, 09:48:25 AM »
dunno if it comes with it. I can soon knock something up, I expect.
Offline Soggz
Re: Storage
« Reply #10 on: August 14, 2019, 09:56:54 AM »
Does anyone have a pic of the mounting plate please?
Offline mw074
Re: Storage
« Reply #11 on: August 14, 2019, 10:04:27 AM »
This.
  • Michigan
Offline Soggz
Re: Storage
« Reply #12 on: August 14, 2019, 12:27:57 PM »
This.
Thanks. How does it mount onto the rack then?
Re: Storage
« Reply #13 on: August 14, 2019, 12:30:56 PM »
This is the This of the previous post after magnification. Knock that out in a couple of minutes using an old biscuit tin.
* top case mounting plate.png (369.4 kB . 472x560 - viewed 739 times)
It snaps into place on a rack designed to accommodate it.
Offline mw074
Re: Storage
« Reply #14 on: August 14, 2019, 12:32:06 PM »
 The mounting plate fits under the OEM luggage rack. The box is then held on by the twist lock pin inside the box,
  • Michigan
Offline Soggz
Re: Storage
« Reply #15 on: August 14, 2019, 12:32:39 PM »
* top case mounting plate.png (369.4 kB . 472x560 - viewed 739 times)It snaps into place on a rack designed to accommodate it.
thanks. Anymore info on it would be appreciated.
Offline Soggz
Re: Storage
« Reply #16 on: August 14, 2019, 12:33:45 PM »
ah ok. Do I need this plate and a special pin of some sort?
Offline mw074
Re: Storage
« Reply #17 on: August 14, 2019, 12:42:14 PM »
This.
  • Michigan
Offline Soggz
Re: Storage
« Reply #18 on: August 14, 2019, 12:44:01 PM »
Re: Storage
« Reply #19 on: August 14, 2019, 12:50:38 PM »
MaxBMW:
 46 54 2 300 449    MOUNTING PLATE     $66.89
Re: Storage
« Reply #20 on: August 14, 2019, 01:15:10 PM »
     $66.89
Indeed. If that can't be reproduced at a fraction of its cost by one of Her Magesty's loyal subjects using tin snips, a biscuit tin and a teacup full of spliffs, the world is indeed off its axis.
Re: Storage
« Reply #21 on: August 14, 2019, 02:03:17 PM »
As per requested, the first one I bought has a manufacture date August 1985. I replaced four of the original rivets with bolts due to the plastic tab inside the box that holds the lid restraint system being broken off. I also added a bit off para cord as a precaution. The hinge looks to be original it has a metal reinforcing strip on the inside of the box to stop the rivets pulling through, this strip is not on the later box. The second top box with the metal hinge was manufactured in May 1986. A mate has a couple of 22Lt boxes but I believe they are a lot later in manufacture, I'll check when I can.
* 22Lt Top box hinge..jpg (41.19 kB . 768x576 - viewed 710 times)
* 22Lt Top box Lid Restraint.jpg (49.91 kB . 768x576 - viewed 644 times)
Offline Soggz
Re: Storage
« Reply #22 on: August 14, 2019, 02:05:00 PM »
I don’t smoke tobacco and paper. It can give people cancer, even over here!
Offline Soggz
Re: Storage
« Reply #23 on: August 14, 2019, 02:50:40 PM »
Thanks . Great pics.
Re: Storage
« Reply #24 on: August 24, 2019, 07:52:09 PM »
After a bit of research there were actually two types of hinges on the Iconic 22Lt Top Boxes the original plastic one part No 46542300450 priced at $10.31. This was superseded by 46542303509 a metal hinge $54.06 on the 15/07/1986.  I took off the OEM plastic one which is starting to fatigue in preparation to replacing it with a modified  tragkorb hinge and it was stamped with the partial part number 2 300 450.
* Plastic Hinge BMW Part No.png (31.31 kB . 768x576 - viewed 621 times)
