Got the bike started today!
Received injectors back on Thursday 7/25 from Mr Injector. The report said that 2 had no pattern and 0 flow, and the other two had bad pattern and a flow of 30. All injectors cleaned up and functioned 100%. The CC/Min after cleaning for all 4 was 160cc.
I first used a q-tip and cleaned the ports in the cylinder head. There was some black residue in there probably from the old o-rings. I then placed all injectors in the rail after lubing the o-rings, put the holding clips on, and inserted the assembly into the ports gently wiggling and tapping with a rubber mallet. Then put the wire clips and wires back on and connected the fuel lines.
Rolled the bike into the driveway and with nervous anticipation pressed the start button hoping to hear it fire to life after many years. No choke, the engine cranked for about 5 seconds and nothing. I figure the fuel had to get through the lines so I took a breath and tried again. This time I could hear it start to turn over so I kept the starter pressed for another 5-10 seconds and let go to a running engine. I gave it some gas and it reved right up (with smoke of course. I had added some oil to the cylinders a few weeks ago for compression). I let it run about 5 minutes and the smoke cleared up. I was surprised at how smooth it was, idling without any misfires at 1.5rpm and reving easily. So I guess the injector cleaning was the limiting factor in getting it started.
I turned it off for now until I can get ready for the next set of items to be looked after.
Can short video clips be uploaded and posted?
