31 42 1450531 spring retainer
Topic: 31 42 1450531 spring retainer (Read 3634 times)
Batkinson
Dumbass Level 1
Motobrick Curious
retread rider....KZ650 30 yrs ago,85 BMW K100 now
May 02, 2019, 04:54:39 PM »
Having the front forks on a 84 K100 LT redone and may be in need of PN: 06 31 42 1450543 (SNAP RING). Mechanic says it needs to be replaced, Bob's reports it never needs to be replaced and there are none in the inventory pipeline all the way back to Germany. Does anyone know where to source a replacement if the mechanic has damaged or lost it ?
(41.58 kB . 674x576 - viewed 622 times)
(23.95 kB . 433x576 - viewed 592 times)
(32.05 kB . 269x576 - viewed 552 times)
Hampton Roads, VA
85 K100, 92 K75
85 K100, eng#F3M698745K335840559, FRAME: WB1051401F0050557,
92 K75 VIN:WB1057105N0133981
Laitch
Faster than a speeding pullet
Administrator
Re: 31 42 1450531 spring retainer
Reply #1 on:
May 02, 2019, 06:47:38 PM »
Get a second opinion about availability. Order it from
MAX BMW
Along the Ridley in Vermont.
1995 K75 102,000 miles
Martin
Reply #2 on:
May 02, 2019, 10:22:44 PM »
A motorcycle suspension specialist might be able to supply one. They often have containers full of various bits and pieces.
North Lakes Queensland Australia
1992 K75s Hybrid, Lefaux, Vespa V twin.
Laitch
Administrator
Reply #3 on:
May 02, 2019, 10:26:08 PM »
Quote from: Batkinson on May 02, 2019, 04:54:39 PM
. . . in need of PN: 06 31 42 1450543 (SNAP RING). Mechanic says it needs to be replaced, . . .
Did he explain to you why it need to be replaced? Broken, incorrect size or what?
Batkinson
Dumbass Level 1
Motobrick Curious
Reply #4 on:
May 05, 2019, 04:53:58 PM »
thanks for the input, i will check with other sources... mechanic just said it was bad, but i am going by his shop Tuesday when he returns.
I am curious what happened also....
Hampton Roads, VA
85 K100, 92 K75
fork fork stanchion
