Author Topic: 31 42 1450531 spring retainer  (Read 3637 times)
Offline Batkinson
  • Dumbass Level 1
  • retread rider....KZ650 30 yrs ago,85 BMW K100 now
« on: May 02, 2019, 04:54:39 PM »
Having the front forks on a 84 K100 LT redone and may be in need of  PN: 06   31 42 1450543   (SNAP RING). Mechanic says it needs to be replaced, Bob's reports it never needs to be replaced and there are none in the inventory pipeline all the way back to Germany. Does anyone know where to source a replacement if the mechanic has damaged or lost it  ?
* Screenshot_20190502-162304.jpg (41.58 kB . 674x576 - viewed 622 times)
* Screenshot_20190502-160916.jpg (23.95 kB . 433x576 - viewed 592 times)
* Screenshot_20190502-160606.jpg (32.05 kB . 269x576 - viewed 552 times)
  • Hampton Roads, VA
  • 85 K100, 92 K75
85 K100, eng#F3M698745K335840559, FRAME: WB1051401F0050557,
92 K75  VIN:WB1057105N0133981
Re: 31 42 1450531 spring retainer
« Reply #1 on: May 02, 2019, 06:47:38 PM »
Get a second opinion about availability. Order it from MAX BMW.
« Reply #2 on: May 02, 2019, 10:22:44 PM »
A motorcycle  suspension specialist might be able to supply one. They often have containers full of various bits and pieces.
« Reply #3 on: May 02, 2019, 10:26:08 PM »
. . . in need of  PN: 06   31 42 1450543   (SNAP RING). Mechanic says it needs to be replaced, . . .
Did he explain to you why it need to be replaced? Broken, incorrect size or what?
Offline Batkinson
  • Dumbass Level 1
« Reply #4 on: May 05, 2019, 04:53:58 PM »
thanks for the input, i will check with other sources... mechanic just said it was bad, but i am going by his shop Tuesday when he returns.
I am curious what happened also....
  • Hampton Roads, VA
  • 85 K100, 92 K75
