Author Topic: This Is The EPIC Soggs 92K75 MAGA Thread  (Read 178873 times)
Offline Soggz
Re: This Is The EPIC Soggs 92K75 MAGA Thread
« Reply #250 on: January 19, 2019, 05:33:16 PM »
I learn from the mistakes of others and appreciate that their hubris benefits me. The Internet has made that convenient indeed and has allowed more of my money to be available for riding and profiterole consumption. I also respect experience, but then I have nothing left to prove, if I ever had anything in the first place. :giggles
I concur
  • Down in Selwood Forest
Offline Soggz
« Reply #251 on: January 19, 2019, 05:35:53 PM »
Soggz, don't take it personal, I have been told not to do things many-many times and I did them anyway. Sometimes it turned out to be OK, other times I ruined the whole thing and had to start anew. With the MAF there is a special MAF cleaner, you can get, and you can hose down the inside, as it is a mild abrasive, that would not damage the sensitive parts. Otherwise do, what I did, use contact cleaner sparingly, do not, at any circumstance touch the temp sensor. Some remove the black plastic cover to clean the insides of the MAF sensor, I am not sure it necessary, unless you know, something is not right there.
Oh BTW, check for air leaks. They can, as with carbed bikes upset the right fuel-air balance and the computer might try to balance for that, or you might run too lean, etc. Use carb cleaner with a long straw and direct the spray to specific parts - throttle body rubbers above and below the bodies, little vacuum caps, vacuum hose to pressure regulator, injectors, the z shaped hose, you have repaired even that big elbow going from the air box to the collector
What happens if you do touch the temp sensor? Just wondering ? It does look fragile.
« Reply #252 on: January 19, 2019, 05:43:44 PM »
You want to learn, don't you? Touch it and find out. How can you believe what anybody tells you? :giggles
Offline Soggz
« Reply #253 on: January 19, 2019, 05:57:45 PM »
I’ve been reading up about it. Is this the sensor which is suspended by wires which heat up electronically, thus knowing when the bike is in cold start mode? Then as the air flows past, it cools, thus letting the computer know that the bike is warming up, so it automatically leans back the mixture for injection flow? And yes, I know not to touch it with bare fingers, but apparently, it can attract dirt and oil over time(a long time), which in itself will give false readings. Therefore, can it be lightly cleaned with a cotton bud (q-tip) and a solvent with very light pressure?
Just asking. Havnt done it, but can it be? As if it is cleaner, wouldn’t it’s reading be more accurate?
« Reply #254 on: January 19, 2019, 06:08:09 PM »
Spray it with carby cleaner or something like that
Offline Soggz
« Reply #255 on: January 19, 2019, 06:11:24 PM »
This is the bit I mean.
« Reply #256 on: January 19, 2019, 06:16:18 PM »
How do you know its reading isn't accurate right now? Is it encrusted with barnacles? Did you inspect it with a jewelers loupe? Has anybody with any significant experience with K-motos recommended that you clean it? Are you getting directives from the Mothership to clean it?
You've got free will. We'll all benefit from your findings, as I have mentioned previously.
Offline Soggz
« Reply #257 on: January 19, 2019, 06:18:46 PM »
Only asking. No such things as stupid questions, only stupid people that don’t ask...like I said... it’s all new to me.
Offline Soggz
« Reply #258 on: January 19, 2019, 06:24:04 PM »
Spray it with carry cleaner or something like that
Then blast it with high pressure and a fine nozzle?
« Reply #259 on: January 19, 2019, 06:32:14 PM »
You could always try spitting on it then beating on it with a rubber policeman.
Offline Soggz
« Reply #260 on: January 19, 2019, 06:37:48 PM »
sorry, it's late. 11.37 pm, to be exact.
And I really don't know what your on about.
« Reply #261 on: January 19, 2019, 06:43:50 PM »
G'night.
« Reply #262 on: January 19, 2019, 07:16:22 PM »
I relate to your idea of buying a spare to rip apart and put together again.
Three weeks ago I got another brick and promised myself not to spend any time fixing it.it was for spare parts only and to rip apart and reassemble.
Then on the way home I thought it would be a shame to wreck something that still goes, after all it used to be illegal to perform an autopsy on something that wasn't dead yet. I defibrillated it (tickled the computer) and now it ticks over again.
Now I havn't got the heart to tear it apart.
« Reply #263 on: January 19, 2019, 08:52:15 PM »
The doohickey(technical term) in the MAF throat is not there to tell if the engine is warmed up.  Rather, it measures AIR temperature very precisely so as to determine it's density/mass.  Air is much denser at colder temperatures than hotter temperatures.  It makes it possible to more accurately calculate the amount of fuel necessary to be injected.
Engine temperature is measured by the water temperature sensor in the cooling passage behind the radiator.
It appears you need to go back and review the Jetronic Manual.
Offline szabgab
« Reply #264 on: January 20, 2019, 01:53:53 AM »
Soggz,  as I recommended earlier,  go easy on that thing,  never ever touch it,  a fine spray of contact cleaner or MAF densor cleaner is all it takes.  If you touch it it is very fragile,  so if it breaks, you will need an another MAF sensor assembly. Since your bike is not running well,  you will not have a benchmark,  and you might never be able to realise,  the heating element is the culprit of a really badly working bike
  • Budapest, Hungary
  • K75S 1985 model
Offline Soggz
« Reply #265 on: January 20, 2019, 03:04:56 AM »
Thank you. I only wanted some sensible answers. It does seem an unusually complicated piece of equipment,and one that I am not famililiar with,but I like to get to know the bike and all its working parts.
Offline Soggz
« Reply #266 on: January 20, 2019, 03:10:23 AM »
Yes,that's understandable. The two bikes I have now,I bought as non runners,so that I could rip them apart,and understand them,and get them going again. 1 done,1 to go! It's getting there. But I do like to think out of the box and ask questions which aren't normally asked...
Offline Soggz
« Reply #267 on: January 20, 2019, 03:12:30 AM »
Thank you,yes,obviously don't want to get heavy handed with sensative components like these.
Offline szabgab
« Reply #268 on: January 20, 2019, 04:17:28 AM »
Also carb cleaner is not recommended,  as it is rather aggressive.  But in my opinion we are obsessing about a thing,  that just needs to be checked for fine operation,  e.g. the door opening and closing freely.  If it does,  just spray the inside a bit and put it back together.  Having the bike operational again check for air leaks methodically,  measure the resistance of the water temp sensor at various temperatures,  and so on...
  • Budapest, Hungary
  • K75S 1985 model
Offline Soggz
« Reply #269 on: January 20, 2019, 04:20:03 AM »
Yup, all done and back in, just before I did the compression test. I was working on the bike until around 8.30 last night.
Offline Soggz
« Reply #270 on: January 21, 2019, 02:53:35 AM »
Hi. Did what you said. The manual is very interesting and I am really delving into it. I’ve never come across a system like this, but this manual helps me to understand the otherwise unseen workings of it all and explains it really easily. Wish I had a hard copy, as I can imagine it would be easier on my eyes than a bright screen.
Thank you.
Offline Soggz
« Reply #271 on: January 21, 2019, 12:44:31 PM »
Ok,managed to start it up today.Before I did that...
Checked the spark,nice and fat and blue.
Compression readings good. But still running rough.
Sprayed contact cleaner at no.3 carcuss,and it stalled.
Going to check the valves in the next couple of days when I have time.
The revs on it sound ' intermittant'.
Choke only seems to work when it's warmed up a bit too. On start up,throttle needs to be wound up and down a lot,and choke dosnt really work for a while,until about 5 mins in,then goes up to 4 k on full,2k on half.Take it off,and bike stalls. What does this sound like?
Thanks.
Offline szabgab
« Reply #272 on: January 21, 2019, 02:54:47 PM »
Thanks.
Well, most likely you have a massive air leak on one of the cylinders,  most likely the one, that stalled after hosing down with contact cleaner.  Use a straw and localised puffs of spray to determine,  where is the leak.
Btw an engine lugging, needing a lot of choke and thumping sound like only two cylinders working
Also if you have that sorted,  see Robert's excellent write-up on the temp sensor resistance http://www.motobrick.com/index.php/topic,11299.0.html
  • Budapest, Hungary
  • K75S 1985 model
Offline Soggz
« Reply #273 on: January 21, 2019, 03:09:00 PM »
Hey!
Thanks for the advice?
Yes,I will have another look tommorow.
« Reply #274 on: January 21, 2019, 03:19:55 PM »
Starting at Reply #108, the coolant temperature sensor discussion was started. Soggz seemed to have tested it with reference to rbm's document, then indicated it passed inspection.
