Author Topic: Rotor pulse  (Read 3290 times)
Offline TX brick
Rotor pulse
« on: November 18, 2018, 11:43:56 AM »
After using nothing but oem BMW pads I decided to try EBC organic pads on the rear 5000 miles ago. All was well until a month ago when I noticed the rear brake pulsing. There is no runout on the rotor and I am wondering if the pads have transfered material to the rotor causing the pulsing?
Ron
91 K75RT
Belton Tx
Re: Rotor pulse
« Reply #1 on: November 18, 2018, 12:48:51 PM »
How did you determine that there was no runout? Try cleaning the rotor and pads with a brake cleaning spray. Allow it to dry thoroughly and test. If it is still pulsing sometimes a light sanding followed by a cleaning will resolve the problem.
Offline TX brick
Re: Rotor pulse
« Reply #2 on: November 18, 2018, 03:30:03 PM »
I used an improvised runout gage.  Allowable is  .0079 in and there is nowhere near that.
I saw on another site that they used a flex hone in a drill to clean and deglaze motorcycle rotors. I tried cleaning and sandpaper with no result.
Ron
91 K75RT
Belton Tx
Offline TX brick
Re: Rotor pulse
« Reply #3 on: November 24, 2018, 12:08:50 PM »
I deglazed the rotor with a rotary hone and the brake is smoother.
Ron
91 K75RT
Belton Tx
Re: Rotor pulse
« Reply #4 on: November 24, 2018, 03:30:20 PM »
 :2thumbup:
