Author Topic: RT Front Suspension K75 1991  (Read 5784 times)
Offline bluebossa
  • K75 and R65 Owner
« on: September 26, 2018, 02:03:13 PM »
Just wondering if it has improved springs or shocks over a C or T unfaired bike... It would make sense considering extra weight of fairing, but is it heavier duty in any way?
Any one know?
  • UK
  • K75C
Current Bikes: K75 (C) in the UK (1986), R45 (1981)
Former Bikes:  K75RT, K75S, R850R, K1100RS, Dnepr MT10-36, R1200GS, K100, R100T, R100RT.
BMW R45 and K75 Blog
Re: RT Front Suspension K75 1991
« Reply #1 on: September 26, 2018, 02:44:48 PM »
Here's a table showing the evolution. The Showa fork was considered superior and was used in production from 8/91.
Offline bluebossa
  • K75 and R65 Owner
« Reply #2 on: September 26, 2018, 06:19:19 PM »
Thanks Laitch - how can I find out if it's a Showa - mine was registered in 6/91
  • UK
  • K75C
« Reply #3 on: September 26, 2018, 07:18:54 PM »
The comparative measurements are found in the fourth column from the right side.
Offline bluebossa
  • K75 and R65 Owner
« Reply #4 on: September 27, 2018, 03:29:06 PM »
Thanks - bloomen eck, 0.3 of a mm - tricky to measure - but tried, seems like 40mm... not got any calipers
Any other outside way of telling whether it's showa or not?
  • UK
  • K75C
« Reply #5 on: September 27, 2018, 06:53:09 PM »
:twak:
Sure, there's another outside way of telling one from the other.
Go to MAX BMW's parts fiche. Go to Model. Click on K75RT. Choose Front Suspension. Compare the axle mount in the diagram of Inner Tube-Sport with the axle mount in the diagram of Fork Slider, which is the Showa. Then look at your photo. Any bells ringing?
« Reply #6 on: September 27, 2018, 07:11:17 PM »
If the Showa was adopted in 08/91 production and yours was registered in 06/91, well then . . .
Offline bluebossa
  • K75 and R65 Owner
« Reply #7 on: September 28, 2018, 12:06:22 PM »
You're a marvellous chap, a detective and I thank you for your patience - Sport then.... not SHOWA
  • UK
  • K75C
Offline bluebossa
  • K75 and R65 Owner
« Reply #8 on: September 28, 2018, 12:07:07 PM »
And as you probably know Laitch - dates and things on Bikes don't always work as precisely as that... but thanks again...
  • UK
  • K75C
