Author Topic: Radial on K75  (Read 4003 times)
Offline Gru
Radial on K75
« on: July 24, 2018, 11:36:45 AM »
I have a K75, 1995, with 3.0 tear three spoke wheel. I want to put a 15/70/17 rear wheel on, has a shim in the wheel, but the radial  is 11mm wider than the stock bias tire. will it work, or will I have to add another shim.
  • Village Mills
  • K75, "CB 500x, Versys 1000, W650, FZ 07
15 Versys 1000, 15 FZ 07, 13 CB500X,          02 W650, 95 K75
Re: Radial on K75
« Reply #1 on: July 24, 2018, 03:58:15 PM »
i went 3 spacers with no adverse effects no tior rubb no off tracking whack...
all these things are tweaked... frames swingarm bushings wheels... gonna have to mess with it...
i can tell you to check tior rubb while the tiors are hot and loaded...
Re: Radial on K75
« Reply #2 on: July 24, 2018, 05:50:12 PM »
Too much shimming and you'll scrape the centre stand on the other side.
Offline Gru
Re: Radial on K75
« Reply #3 on: August 02, 2018, 10:06:29 PM »
The shims are closer to 1.3mm, hope three will be enough. Tires ordered, shims waiting to have some fun getting things lined up.👍
  • Village Mills
